02/06/09 05:52 AM02/06/09 05:52 AM #1 Started to remove the icc and security code error has come up on the screen I have not got it out all the way and did pull or jurk it was the go how can I fix this.
02/06/09 06:14 AM02/06/09 06:14 AM #2 disconnect battery for a start, u shouldnt be removing it with power still connected.disconnect battery and push back in then reconnect and c if ok.if so try again. as u pull it forward the plugs on the back disconnect them selfs that's prob what u saw happen. but for chris saake dont do it with the battery connected. y u removing anyway?
02/06/09 07:51 AM02/06/09 07:51 AM #3 Author took your advice all is good. removed to run wiring for the gauges on the dash thanks for your help.
