  • Member For: 21y 7m 13d
I got one the other day and must say it is very usefull if you understand what you are doing with it.
I got capa to supply me with a generic tune that was ok(after 5 different attempts), and on the dyno I was able to fine tune it with the controller. - I must admit that the base tune must be close before you begin.
My mechanically standard Typhoon now has 255rkw and I have the ability to increase/Decrease timing or fuel depending on the situation/driving conditions or fuel used.
Cheers
  • Member For: 19y 1m 18d
heres some food for thought.
mine is off a custom tune corty, and having the same ability as you heaps of ajustment, my car is tuned for around 340 rwkw.
I have put on an unboltable muffler to keep the beast quiet on the street this required about 3 degrees of timing to be removed, when I put the big rear pipe back on it gets the timing put back in .
its good when theres no premium around pull out 10 degrees make it 14%richer and still run 14psi..lol..
and using the fan settings I can keep it a bit cooler also.
  • 2 weeks later...
  • Member For: 16y 7m 14d
That is good to know, will have to get one and have a play with it. I have played around with a EMS Dualsport on an ae86 4AGE 20v before, and that was very interesting, and this sounds even simpler and better
