  • Member For: 17y 10m 9d
This is a weird one to me, but may be a known problem for some of the wiser heads out there.....
Scenario: Sitting at the lights, you decided to give it a bit as the speed limit up ahead is 100km/h. So you do you get to 120km/h and you feel what can only be described as a vibration and a burble when the accelerator is on....you go off gas, the revs drop and the problem ceases...you put your foot back on the accelerator, and the vibration/burble comes back.......after approximately a minute or so, the problem goes and it appears to be back to normal running.....
This has happened to me on a couple of occasions and I'll be f**ked if I know what it is....
Any ideas ????
https://www.fordxr6turbo.com/forum/topic/38667-engine-problem/
Guest EGOXRT
  • Guests
Any ideas ????
Does it always happen under load and at any speed? Could be a coil pack..
  • Member For: 21y 1m 23d
tuned or stock?
if tuned what are the gaps set at?
When were the plugs last changed?
When was the fuel filter last changed?
"after approximately a minute or so, the problem goes and it appears to be back to normal running.....
So after a coulple of squirts it then goes away, and wont return even when you give it a squirt the third or fourth time etc?
What fuel are you running?
does it happen when its hot?
It sounds like a spark or fuel prob to me. There could be a fault code thrown into the ecu, so if you take your car to someone who can scan for codes this might help.
good luck mate
Car is a 4sp Auto
tuned or stock? Running a 8psi generic tune
if tuned what are the gaps set at? 0.7
When were the plugs last changed? 4 weeks ago
When was the fuel filter last changed? 2 months ago
So after a coulple of squirts it then goes away, and wont return even when you give it a squirt the third or fourth time etc? I've had it happen a couple of times in a short 30 min drive.....
What fuel are you running? 98 Octane
does it happen when its hot? Yes
