Guest EGOXRT Guests Posted 22/08/06 12:43 PM Share Posted 22/08/06 12:43 PM Hi there all. I am about to install an lc6 and was wondering if anyone has already done this?? What I really need to know is, the best place to splice the front speaker wires. Is there a plug near the icc ??? Is the anywhere this can be done in the kick panels?? I have removed the drivers side kick panel an was hoping it could be done through there as removing all this trim is Any advise is appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/27959-speaker-wire-splice/ Share on other sites More sharing options...
BuckleRTV Member 2 Member For: 18y 8m 15d Posted 26/09/06 08:55 AM Share Posted 26/09/06 08:55 AM (edited) Mate I got an Falcon RTV and strugled to find any one that knew what to do... so went for it and figured it out.Take out all of the front passenger panelling till you can get be hind the kick panel.2 of the wires (Probably Orange) go to the left Door another 4 were spare on my ute so I used them for a set of 6x9's the same.They are the thin wires in the orang socket Pink and Blue from memory for the back left an right chanel.Buckle... Edited 26/09/06 09:01 AM by BuckleRTV Link to comment https://www.fordxr6turbo.com/forum/topic/27959-speaker-wire-splice/#findComment-441089 Share on other sites More sharing options...
wasxaman Member 37 Member For: 18y 1m 23d Gender: Male Location: Melbourne Posted 21/04/07 10:28 AM Share Posted 21/04/07 10:28 AM The best place to access the front speaker wires is definitely the front kick panel. Forget the back of the ICC.The colour codes for the wires in a BA are as follows:Right Hand Kick PanelFront Right - Grey/Black + Grey/OrangeFront Left Kick PanelFront Left - Orange/Black + OrangeRear Left - Pink/Black + PinkRear Right - Blue/Black + Blue/RedDouble check the color code in your car by removing the speakers and checking.When you open the kick panel, you will see a birds nest of cabling running parallel with each other - except the speaker pairs, they will be twisted together making them easier to identify.Its a fiddly job.Good Luck 1 Link to comment https://www.fordxr6turbo.com/forum/topic/27959-speaker-wire-splice/#findComment-524453 Share on other sites More sharing options...
PIT STOP Member 64 Member For: 18y 2m 1d Gender: Male Location: SYDNEY Posted 21/04/07 11:15 AM Share Posted 21/04/07 11:15 AM speakers wire as above take powers from the phone plug up under right hand side of dash in a blue plug 12 acc,12 permanent,earth ,are there that way your not hacking up too much of your cabling. Link to comment https://www.fordxr6turbo.com/forum/topic/27959-speaker-wire-splice/#findComment-524467 Share on other sites More sharing options...
Max Power Member 381 Member For: 21y 1m 7d Location: MENAI, NSW Posted 21/04/07 02:19 PM Share Posted 21/04/07 02:19 PM Definitely splice in the speaker wires noted above behind the passenger kick panel. that's where I did mine. Link to comment https://www.fordxr6turbo.com/forum/topic/27959-speaker-wire-splice/#findComment-524503 Share on other sites More sharing options...
