Typhoon 19" Wheels
Featured Replies
#11
  • Author
Reply to BF F6
THIS IS NOT CORRECT THAT THE REAR RIMS WILL NOT FIT THE FRONT BECAUSE OF FOULING THE BRAKES.
IN FACT YOU WOULD BE BETTER OFF USING ALL REAR RIMS AS THEY HAVE AND CREATE MORE ROOM DUE TO THE BIGGER OFF SET. 10MM
THIS IN TURN GIVES A WIDER TRACK TO THE VEHICLE MORE ROOM ETC ETC FOR THE BRAKES.
THE ONLY PROBLEMS YOU WILL HAVE IS FOULING ON THE FRONT GUARDS WHEN TURNING INTO A DRIVE WAY.
PUTTING REAR RIMS ON THE FRONT AND FRONTS ON THE BACK WOULD ONLY LOOK FUNNY BUT THEY WILL ALL FIT.
I USE AU PURSUIT RIMS ON MY BF F6 AND WORK GREAT AS THESE ARE ALL THE SAME OFF SET.
You've just confirmed what I was thinking, but the question is do the Mk1 BA XR 18" wheels fit????
Big AL
#12
Cant see why not as I dont think they had different wheels when you ordered the Brembo package.In the BA range.
Bud dosnt take long to try one and see
#13
  • Author
That's exactly what I intend to do.
Big AL
  • 1 month later...
#14
Reply to BF F6
Ok ... I have a question : )
Does anyone know if the FPV BF GTP rims are the same as the FPV BF Super Pursuit GT ute?
They look identical but was wondering if the rears have the same 10mm wider offsett as the sedan variant??????
Thanks
#15
  • Author
Reply to BF F6
Thanks
I'm not sure of the exact answer but it's easy to tell. Simply look at or measure the thickness of the wheels' hub. It's obvious when you compare front and rear that the rear hub is about 10mm thicker than the fronts. I was told all FPV's have the offset difference but I'm not 100% sure.
Big AL
Recently Browsing 0
