29/07/06 02:26 AM29/07/06 02:26 AM #1 got some work done to my mk2 ute a while back...exhaust, injectors and bigger in-tank pump, custom tune etc.from day one the fuel gauge had been nuts, basically reading full when empty and vice versa etc, though it jumps from one to other - no smooth needle movement as tank empties either....I was not too concerned as I live along way from tuner, and will be going back soon for some more mods, but they reckon it may be a corrupt file (??? something like that) in the downloaded tune they modded... if that was the case, would it not be normal when I flash it back to standard???has anyone had similar experience???thanks for your input.
29/07/06 02:29 AM29/07/06 02:29 AM #2 got some work done to my mk2 ute a while back...exhaust, injectors and bigger in-tank pump, custom tune etc.from day one the fuel gauge had been nuts, basically reading full when empty and vice versa etc, though it jumps from one to other - no smooth needle movement as tank empties either....I was not too concerned as I live along way from tuner, and will be going back soon for some more mods, but they reckon it may be a corrupt file (??? something like that) in the downloaded tune they modded... if that was the case, would it not be normal when I flash it back to standard???has anyone had similar experience???thanks for your input.←Is your range to empty readout doing the same thing...is that accurate????
29/07/06 02:34 AM29/07/06 02:34 AM #3 is the sender unit in the fuel tank anything to do with the pump? perhaps it may have been damaged when changing pumps
29/07/06 10:29 AM29/07/06 10:29 AM #4 agree with above, did you have a fuel pump change or modfiction seems the sender unit is playing up.
30/07/06 03:10 PM30/07/06 03:10 PM #5 mail them your edit (if that's what u run) and get them to look at the settings since u live a distance from them.send it registered post
31/07/06 12:03 PM31/07/06 12:03 PM #6 Author thanks for the input guys....trip computer is erratic like the gauge with kms remaining etc...I have agut feeling the sender has issues now, no fun in a ute either...keep u posted, either way, my tuner better come to the party....
