July 7, 200521 yr #1 GuysMy next mod is for the edit and valve springs with injectors after that.What is the best valve springs to use.CheersAdrian
July 7, 200521 yr #2 GuysMy next mod is for the edit and valve springs with injectors after that.What is the best valve springs to use.CheersAdrian<{POST_SNAPBACK}>F6 springs will do
July 7, 200521 yr #3 You still up at the dyno tomorrow Adrian?I’m sure with all the boyz there Saturday you will have many suggestions and answers to your questions with results.I’ve got a few myself but best wait and see what the numbers are and compare them to the amount of mods after the dyno.
July 7, 200521 yr #4 Author I dont I can buy them for the sake that they are an FPV item.How about nizpro springs
July 7, 200521 yr #5 F6 springs will do Sorry to go OffTopic but are you still running F6 Springs at 300+rear wheel?Lumpy
July 7, 200521 yr #6 Author Yeah ill be there.I fly in to perth tomorrow night.Your right. All my questions should be answered then but hey im at work and got nothing to do so what better then to start asking questions that have already been answered.
July 7, 200521 yr #7 Adrian the part number is BA2T6513A and is available over the counter.I know where you can get a F6 Brand new set for $150 if you want them let me know.Lumpen Proletariat ~ Yes I have STD F6 springs and run 13PSI boost at present.Not a problem. Edited July 7, 200521 yr by F6_Tornado
July 7, 200521 yr #8 Do you need a VIN number to order the F6 Springs and how much would they be approx?
July 7, 200521 yr #9 Do you need a VIN number to order the F6 Springs and how much would they be approx?<{POST_SNAPBACK}>No ViN Number req!!!!!New from Coventrys is @ $7 Plus GST from memory.Part Number is BA2T6513A Give them a ring today and ask as Im not 100% sure on the exact price. Its around $7 each.Mine cost me $56K and came with a Ute
July 8, 200521 yr #10 Okay, here's my stupid question for the day - how many valve springs in a set?! You said a set was $150, and then that they were about $7.70 ($7 + GST) each - that makes about 19 springs (probably 18 in a set?) in my books?!
