Trough Lolly Member 4,349 Member For: 20y 8m 8d Gender: Male Location: Mildura Posted 19/01/05 07:36 AM Author Share Posted 19/01/05 07:36 AM cool thanks for the help guys! Link to comment https://www.fordxr6turbo.com/forum/topic/15241-xr-foglights/page/2/#findComment-210645 Share on other sites More sharing options...
Cro Flower Power Lifetime Members 6,114 Member For: 22y 7m 6d Gender: Male Location: Sydney Posted 19/01/05 10:12 PM Share Posted 19/01/05 10:12 PM Oh, and make sure you do one at a time.I accidently swapped the RH and LH lights leaving a big gap, and left the lights crossing over eachother.<{POST_SNAPBACK}>This might explain the gap I have in mine at the side, they were removed when my bumper was resprayed... I didn't know they were L and R specific though...<{POST_SNAPBACK}>The lights arn't but the brackets are.On the back of the brackets they have engravings LH and RH. Link to comment https://www.fordxr6turbo.com/forum/topic/15241-xr-foglights/page/2/#findComment-210792 Share on other sites More sharing options...
Cro Flower Power Lifetime Members 6,114 Member For: 22y 7m 6d Gender: Male Location: Sydney Posted 21/03/05 11:14 PM Share Posted 21/03/05 11:14 PM Oh and they are 7mm hex bolts holding the stone tray up. Link to comment https://www.fordxr6turbo.com/forum/topic/15241-xr-foglights/page/2/#findComment-234113 Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 7m 6d Gender: Male Location: South Coast NSW Posted 22/03/05 02:01 AM Share Posted 22/03/05 02:01 AM That's the head size not the thread size. 7mm socket Link to comment https://www.fordxr6turbo.com/forum/topic/15241-xr-foglights/page/2/#findComment-234204 Share on other sites More sharing options...
Cro Flower Power Lifetime Members 6,114 Member For: 22y 7m 6d Gender: Male Location: Sydney Posted 22/03/05 02:43 AM Share Posted 22/03/05 02:43 AM :lol: Link to comment https://www.fordxr6turbo.com/forum/topic/15241-xr-foglights/page/2/#findComment-234222 Share on other sites More sharing options...
stang Donating Members 1,353 Member For: 21y 3m 26d Location: Melbourne Posted 10/06/05 09:57 AM Share Posted 10/06/05 09:57 AM What wattage are the fog lights and how much should I pay?I only have one blown, should I get form Ford ,autobahn or whoever Link to comment https://www.fordxr6turbo.com/forum/topic/15241-xr-foglights/page/2/#findComment-261797 Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 7m 6d Gender: Male Location: South Coast NSW Posted 11/06/05 10:43 AM Share Posted 11/06/05 10:43 AM 55w - you'll get better globes from Ford than Autobarn I think. Link to comment https://www.fordxr6turbo.com/forum/topic/15241-xr-foglights/page/2/#findComment-262134 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 2m 1d Gender: Male Location: Darwin NT Posted 11/06/05 11:41 AM Share Posted 11/06/05 11:41 AM The fog light is also directly replacable with a hella driving light part no 9.1313.01 Link to comment https://www.fordxr6turbo.com/forum/topic/15241-xr-foglights/page/2/#findComment-262155 Share on other sites More sharing options...
Goobz Member 746 Member For: 20y 7m 5d Location: Sutherland Shire, Sydney Posted 13/06/05 01:11 AM Share Posted 13/06/05 01:11 AM The fog light is also directly replacable with a hella driving light part no 9.1313.01<{POST_SNAPBACK}>Any idea how much these go for?Chris Link to comment https://www.fordxr6turbo.com/forum/topic/15241-xr-foglights/page/2/#findComment-262525 Share on other sites More sharing options...
cqae Member 229 Member For: 21y 6m 11d Posted 13/06/05 09:37 AM Share Posted 13/06/05 09:37 AM another way to look at it boys-is stay away from the stone tray. Its too low to be dealing with if you dont have a hoist or dont wanna jack it up. I think the easiest way is to partially undo the stone shield in the wheel arch. Turn the steering wheel full locki to expose it-remove a few clips & screw & you can get your hand right in behind the light. Then you can use a small screw driver to release the clips & push the entire lamp insdie the spolier. Dont turn the screw as a few previous posts have mentioned, it has no help with removal & is only for adjustment of the lamp. There are clips u can press from inside the spoilet if u dont want to use the screwdriver, I find themk hard to push in-not enough give in the plastic-just dont push too hard. You can easily break the pivot point. hope this helps-one other things, be careful of puting higher wattage globes cos newer lamps are made of plastic instead of glass & higher globes or non uv cut globes can damage them. go for a plus 50 or similar blue style globe which are same wattage but higher light output. and a h1 or h3 should retail at around 8-9 bucks or up to 16-17 for the arctice blue or plus types all the newer narva, hella & phillips are uv reduced and just a point hella globes & many others are manufactured by phillips anyways or it might be optilux, the h4s in the headlights are hella plus 50 from new I pulled mine out to change them & they are identical to the ones I had to put in. Link to comment https://www.fordxr6turbo.com/forum/topic/15241-xr-foglights/page/2/#findComment-262695 Share on other sites More sharing options...
