mikea1988
Everything posted by mikea1988
  1. Think my cheapest option is to try 2 new rear tyres 245 35 20 rear tyre with stretch then cross my fingers that I haven't wasted $300 lol And just to confirm 245 35 20 rear tyre with stretch will fit my +40 offset hence the stretch im guessing?
  2. My rears are 20x10 though not 20x 8.5 which is why I'm guessing you had no rubbing
  3. What if I put 8.5 inch in the rear aswell instead of the 20 x 10's would that avoid any rubbing?
  4. Gaz are u in melb?
  5. Rear is +40 mm
  6. So you think different tyres even though the width is 10 inches would avoid any rubbing?
  7. Tyres are pretty much new. Didn't want to spend 5-600 bucks on new tyres again. They really should be rolled.
  8. Will look sh*t with only one side rolled. Plus they will both have to be done before it gets on a dyno. Rear rims are 20 x 10 Panel shop my only option?
  9. Hey guys I need to have my rear guards rolled on my ba mkii. Went to a local bloke uses the rolling tool however he noticed some filler having been rubbed on the inside of my right wheel arch. He said he can't use the rolling tool because the filler won't bend and the guard would just snap. What are my options? Rims are slightly scrapping on big dips in the road so want this fixed especially for when it gets strapped down on a dyno again and it really squats. Left side can be rolled just dont know what I can do for the right side with filler rubbed in the wheel arch. Your help is greatly appreciated.
  10. So these 25mm adapters that's Henz mentioned are extremely dangerous?
  11. Maybe a 5x100 adapter to 5x 114.3 Current offset is 35
  12. Is there any spacers or anything that can change the stud pattern to make them fit??
  13. Offset is 35 all round
  14. Hey guys I purchased some wheels second hand. 20x 235 x 8.5 The problem is the stud pattern is 5x 100 I need to get these on my ba mkii xr6t Any suggestions would be greatly appreciated Cheers
  15. Hey guys Wondering if any of you have shipped 4 x wheels (tyre and rim) interstate before? Who did you use? How did you package it? The wheels wih tyres won't fit in normal rim box. Buying from someone interstate 2nd hand. Your insights are greatly appreciated. Cheers
  16. Will it make a noticeable delifference in look??
  17. Cheers. More looking at responses to my initial questions.
  18. Hey guys Looking at these for my BA mk ii http://www.fwt.net.au/products_closeup.asp?part=&part_no=2932&Name=Versus+Wraith+ Should I go 20x8.5 front and 20x10 rear Or All 20x8.5 Also will this be roadworthy? Any help is greatly appreciated. Cheers
  19. Just interested to know how they effect it
  20. Hey guys Just wondering when going from 19inch to 20 inch rims what is the general rule of thumb for the power loss that would occur? car is 293rwkw atm on 19s
  21. ok so im looking at a high flow venom cat with 3 inch inlet with 5 inch body which the exhaust shop said they will make up an adapter to run straight into my standard exhaust from there back.
  22. Although I should have asked will my standard rear muffler need to be changed also to something more high flow for 320rwkw?
  23. the highflow cat like you did FINNEY and stock system from there will be fine. 320 rwkw will be as far as im taking it.
  24. Sweet. I can get a high flow cat for $200 I have my standard exhaust under the car port. Will get them to install my new cat and old standard exhaust from cat back then go back on the dyno.
  25. Hey guys Had the car tuned and my tuner has said the current exhaust system is restricting us. It has standard ba dump and then into a cat back single 3inch x force system to twin tip muffler. What is the cheapest way I can get this able to flow for 300to 320rwkw? Im thinking 3inch inlet with 5inch body high flow cat then run that into the stock system all the way back? Dont want to spend a heap of cash on this that's all. your help is greatly appreciated.
