  • My new toy
  • Legacy Donating Member
  • Member For: 23y 5m 5d
Posted
Hi guys as I mention in the intercooler thread I was working on oil coolers for the auto and engine.
I have now fitted them,what I have done is make up a mounting unit with a transmission oil cooler and engine oil cooler with a fan attached to the unit.
As some of you know under the left hand rear of the turbo there is a lot of room so I have mounted them under there with braided hoses running up to the auto and adaptor to the oil filter.
This removes the heat of the auto from the rad and also cools the engine oil.
As it has only just been fitted I have not been able to do full temps yet but with the hot day we had on the gold coast today I let the motor idle for 30 minutes after taking it for a run,with a/c on and sitting in hot workshop the main cooling fans did not go on to high speed at all.
The fan on the cooler as an adjustable controll on it and I have temporary set it to cut in at oil temp of 70 degrees.
At this temp the fan runs for about 2 minutes when I cuts in when driving,if driving hard on boost it runs more of course as oil temps rise.
I will post some pics to go with this.
  • My new toy
Posted
Pic one is of where I mounted the coolers.
  • My new toy
Posted
The coolers before being mounted.
  • My new toy
Posted
Coolers mounted with fan which draws the air down.
  • My new toy
Posted
Shot of hoses at the back.
  • My new toy
Posted
Last shot of hoses along chassis rail.
  • FORD FORD FORD
  • Member For: 23y 6m 10d
Posted
Well done Ian,
I'm keen to see costs & road test reports from you. Should reduce heat considerably & improve grunt factor!
Scotty
Guest EXR24T
  • Guests
Posted
well done mate . your a top bloke for sharing the mods you are currently undertaking with the rest of us .
thanks again timmy !!
Posted
Holy watsaname,that's some serious cooling, what about your other oil cooler,did you ditch it?
The trans must have extra cooling,was thinking of getting the V8 trans cooler but this looks the way to go.give your self a free plug mate, what is your shop called, Im in SA and dont know.
vik
  • My new toy
Posted
Hi guys the car this is fitted to is a mates car I was going to put it on mine first but he insisted I do his.
Vik the smaller cooler is the same as my engine oil cooler so when I do mine I will just move it to this location.
My workshop is Ian Schmidt Auto Repairs.
Although it is not cheap to do I think it is great insurance when you are going to do any mods to keep the trans and engine oil cooler.
Hope to have mine fitted soon so I can do more tests.
