July 18, 200917 yr #1 G'Day ,As the title suggests, I am currently looking for a diff and have found this diff. The seller claims that the diff has 3.7:1 ratio. The yellow lable with the ratio has conveniently 'come off'. I took a look at the diff and subframe and found the following numbers..DIFFSUBFRAMECan anyone tell me what model/ratio this diff is off and the best way to tell the ratio?Cheers,AJ Edited July 18, 200917 yr by Phooned
July 18, 200917 yr #2 the easiest way to check, is turn the pinion 3.7 times, and the cv should turn once. David
July 18, 200917 yr #4 Author Thanks David and Trevs for the quick reply!...what ratio is your diff Trevs? Also, the number on the subframe ends with a BA (did Ford use the same p/n for the BFs?) Edited July 18, 200917 yr by Phooned
July 18, 200917 yr #5 you might be able to do it by the numbers, but im not sure, but if it is 3.7, it will be out of a 6speed man,xr6t, xr8, GT, and will be limited slip, will not fit in a normal xt cradle,ive been told but have not seen for myself. David
July 18, 200917 yr #6 Author you might be able to do it by the numbers, but im not sure, but if it is 3.7, it will be out of a 6speed man,xr6t, xr8, GT, and will be limited slip, will not fit in a normal xt cradle,ive been told but have not seen for myself. DavidAah ok. This diff comes complete with the IRS cradle, springs and axles. Just wanted to check what ratio it was before I put down the $$. Thanks heaps!Cheers,AJ
