  • Member For: 12y 11m 24d
Hi all what would cause a
Forced limited shutdown
And maximum speed reached
Codes at startup...not all time but can be when cars cold or warm. Downt matter
Ot started revs up and the missfired all over place till turning off. And on again then will drive fine etc
Also while just idleing normally it will do same ....idleing fine then all sudden does this. But as said not all time
Throttle body and TPS replaced every other sensor knowm to man kind replaced bo vacune leaks etc wireing looks all good have reseated the wireing into ecu...earths all good.
Only thing left is pedal sensor and PCM
https://www.fordxr6turbo.com/forum/topic/97428-pedal-sensor-faulty/
