greasemonkey Member 97 Member For: 7y 4m 22d Posted 21/09/24 07:25 AM Share Posted 21/09/24 07:25 AM Hi Guys I know a few of you would have removed the Auto Trans from your XR6 Turbos. I'm currently in this process to renew my Rear Main Seal. Found a few other parts need replacing also. 1)I can't get a spanner to the nut at the back to remove the tailshaft 3 bolts from the coupling. There is no room there. How did you guys do it? Did you lower it first and then undo those 3 bolts 2) WHERE ARE THE TORQUE CONVERTER BOLTS UNDONE FROM? I can't see a viewing window or space anywhere on my ZF. Workshop manuals including the Ford manual have not been of great help? 3) DO I NEED A SPECIAL TRANSMISSION LINE DISCONNECT TOOL FOR THE TRANSMISSION LINE FITTINGS AT THE HEAT EXCHANGER? (LAST PICTURE IS FROM EL ANDREWS THREAD OF THE AUTO FAN COOLER. Good pic to demonstrate what I'm talking about). ALWAYS APPRECIATE THE HELP from you guys! Link to comment https://www.fordxr6turbo.com/forum/topic/97340-fg-mk1-xr6-turbo-automatic-transmission-removal-zfhp26/ Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,301 Member For: 10y 2m 30d Gender: Male Location: South Australia Posted 21/09/24 07:49 AM Share Posted 21/09/24 07:49 AM Answers are: 1. Don't undo those ones, undo the other ones. Leave the rubber donut attached to the tailshaft. 2. Through the starter motor hole. 3. Undo that bolt for the black bracket on the trans. From there you can lever the lines out from the trans. Move them to the side, no need to undo the heat exchanger side to remove the trans. Those quick connects are easy to undo though, spray them with WD-40 and move them back and forth a few times, then you can undo them by hand. There's probably a tool for it, I know you can get quick connect tools for fuel lines etc. Google is your friend Link to comment https://www.fordxr6turbo.com/forum/topic/97340-fg-mk1-xr6-turbo-automatic-transmission-removal-zfhp26/#findComment-1724347 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,439 Member For: 17y 18d Gender: Male Location: Melbourne Posted 21/09/24 07:52 AM Share Posted 21/09/24 07:52 AM 1. Use a socket and extension? 2. There should be a plate you can remove from the bellhousing (connection between gearbox and engine) and you can remove that to do the converter bolts... or you take out the starter motor and use that hole to do the bolts. 3. They're probably the same as fuel line hose connections, but I don't know the answer to this one... looks like a connector that you have to push "inwards" from the sides and then pull/jiggle. Link to comment https://www.fordxr6turbo.com/forum/topic/97340-fg-mk1-xr6-turbo-automatic-transmission-removal-zfhp26/#findComment-1724349 Share on other sites More sharing options...
greasemonkey Member 97 Member For: 7y 4m 22d Posted 21/09/24 01:55 PM Author Share Posted 21/09/24 01:55 PM Puff and K31th 6 hours ago, Puffwagon said: Answers are: 1. Don't undo those ones, undo the other ones. Leave the rubber donut attached to the tailshaft. 2. Through the starter motor hole. 3. Undo that bolt for the black bracket on the trans. From there you can lever the lines out from the trans. Move them to the side, no need to undo the heat exchanger side to remove the trans. Those quick connects are easy to undo though, spray them with WD-40 and move them back and forth a few times, then you can undo them by hand. There's probably a tool for it, I know you can get quick connect tools for fuel lines etc. Google is your friend Thanks Puff for the answers for 1,2 and 3 (helps me out so much). Can you remember how many torque converter bolts exist? Thanks K3ith as well for the info about the connectors. I'll try to pry out the lines at the transmission first, leave the others connected and then put them back in later. Will try to remove the trans tomorrow. Starter motor and inlet manifold already removed. I just jacked the car up though quite high so hope the bonnet doesn't hit the roof when I open it up to start removing the torque converter bolts. Link to comment https://www.fordxr6turbo.com/forum/topic/97340-fg-mk1-xr6-turbo-automatic-transmission-removal-zfhp26/#findComment-1724358 Share on other sites More sharing options...
hjtrbo Bronze Donating Members 322 Member For: 14y 3m 9d Posted 21/09/24 05:16 PM Share Posted 21/09/24 05:16 PM 4 tc bolts. Mark it. Have a weak memory of the way they're orientated the tc can only ever go back to the same spot. When you have the tc bolts out use a pry bar to gently push the converter towards the transmission. It should move back about 5-10mm. That'll get the tc spigot out of the crankshaft bore. Link to comment https://www.fordxr6turbo.com/forum/topic/97340-fg-mk1-xr6-turbo-automatic-transmission-removal-zfhp26/#findComment-1724359 Share on other sites More sharing options...
greasemonkey Member 97 Member For: 7y 4m 22d Posted 22/09/24 01:24 AM Author Share Posted 22/09/24 01:24 AM Thanks HJ. I'll be mindful of the bolts and will mark them the best I can. I'll also use the pry bar just to get it off. WISH ME LUCK!!! Link to comment https://www.fordxr6turbo.com/forum/topic/97340-fg-mk1-xr6-turbo-automatic-transmission-removal-zfhp26/#findComment-1724363 Share on other sites More sharing options...
greasemonkey Member 97 Member For: 7y 4m 22d Posted 22/09/24 07:21 AM Author Share Posted 22/09/24 07:21 AM Alright guys. I'm only a few bolts away. How do I get the transmission rear electrical connector off?? Did all the torque converter bolts and just have 3 or 4 bellhousing bolts. Surpised with the bellhousing that they are not on super tight! Link to comment https://www.fordxr6turbo.com/forum/topic/97340-fg-mk1-xr6-turbo-automatic-transmission-removal-zfhp26/#findComment-1724365 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,301 Member For: 10y 2m 30d Gender: Male Location: South Australia Posted 22/09/24 08:14 AM Share Posted 22/09/24 08:14 AM Push the connector tab upwards. Give it a tap with something if you need to get it moving, but usually you can just thumb it up there. It gets tight at the top too, so do it in one hit. Link to comment https://www.fordxr6turbo.com/forum/topic/97340-fg-mk1-xr6-turbo-automatic-transmission-removal-zfhp26/#findComment-1724366 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,439 Member For: 17y 18d Gender: Male Location: Melbourne Posted 22/09/24 09:02 AM Share Posted 22/09/24 09:02 AM you mean anti-clockwise haha... Link to comment https://www.fordxr6turbo.com/forum/topic/97340-fg-mk1-xr6-turbo-automatic-transmission-removal-zfhp26/#findComment-1724367 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,301 Member For: 10y 2m 30d Gender: Male Location: South Australia Posted 22/09/24 09:46 AM Share Posted 22/09/24 09:46 AM Yes, anticlockwise aka upwards, unless you are removing your trans with the car on it's roof. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/97340-fg-mk1-xr6-turbo-automatic-transmission-removal-zfhp26/#findComment-1724368 Share on other sites More sharing options...
