06 ghia turbo
Jeverz
  • New Member
  • Member For: 3y 6m 14d
Thanks mate.
I'm caught up in two minds with it.
Not sure if I should sell it or go down the rabbit hole..
Since I've owned it I swapped out the parts below
FRONT
rotors slotted dba
pads dba sp
lower control arms nolathane
radius arms nolathane
sway bar links nolathane
sway bar  d bush nolathane
left and right new driveshafts gsp
diff oil nulon 80-140fs
REAR
pads dba ss
sl king springs
bump stops nolathane
engine mounts
earls turbo oil feed filter braided line
braided turbo coolant lines
silicone hose kit
catch can - still need to hard mount
4" intake k&n filter
de bung exhaust
adrad radiator
adrad overflow bottle
82°? thermostat
intake manifold gaskets - mace plenum spacers top and bottom.
PWR transmission cooler - heat exchanger removed.
external inline transmission filter
ryco transmission pan filter
new genuine ford plugs 7s
new genuine ford coil packs
fresh coolant
fresh engine oil + filter
new fuel filter - 98 fuel only
new cabin filter
full led conversion, every bulb is led inside and out.
turbosmart boost gauge
My initial plans were
Plazmaman intercooler + plenum kit
injectors
fuel pump+reg
exhaust
and then ive been reading on the PCMTEC software and some people are using bits of the f6x tune. All the pcm tec stuff would take me a while to wrap my head around but yeah that's the yarn for the day
  • New Member
Put a new 02 sensor in the factory dump pipe today, seems like someone has tried to have a go in the past but ended up rounding it off so that was fun.
Nice and smooth now though.
Also swapped out all of my door lock actuator gears, Was fighting the temptation to upgrade the speakers while I was at it but I think I will sell the car, I can see myself falling down that rabbit hole very quick.
  • Puff
  • Member For: 10y 8d
Your initial plans with the exhaust and front mount etc is about all you'd want to do, even though it'll still set you back around 6k for parts. You'd need an actuator too and with fitting and tuning will bring that up to nearly 10k. You'll be able to make mid to high 300s on 98 which is pretty decent.
Much more than that and the trans will be overly stressed and the engine won't be very happy either.
Would you sell your car now for 2 to 5k? That what will happen when you spend 10k on it and can only sell it for 12 to 15k if you're lucky.
A tune only will take you from the stock 180awkw up to 220awkw, that might be an idea for a bit more poke.
  • New Member
3500 cooler kit and plenum
1500 injectors, fuel pump, reg and relay
1300 exhaust, actuator
give or take a few here and there was how I was looking at it, I would only need help with the tuning side of things not necessarily the installation of the parts. The other thing I would want to do is timing chain and oil pump gears.
I'm curious as to what you think they're worth at the moment?
Can a tune as is take me to 220awkw?
I'm no expert but I don't think any Ghia turbos came with the earlier ba turbo motors, I'm probably wrong though
  • Puff
I've tuned a dead stock unit and the most it made was 230awkw but turned it down to 220 for a bit of safety as the injectors are maxed out.
The general consensus is 06/2006 onward have the better rods. Whether this is gospel, I don't know.
As to their worth, it depends on condition. Anywhere from you couldn't pay me to take it up to 10k I suppose.
