Jarednz New Member 7 Member For: 1y 4m 6d Posted 21/05/23 02:49 AM Share Posted 21/05/23 02:49 AM So have recently tuned my fg G6et made 380kw (16psi) on 98. Was curious what else I would have to do to make more power 400-450kw, the current mods are as follows 6boost manifold 4” exhaust gtx3584rs turbo pulsar intercooler 45ml external gate 1000cc injectors wahlbro 450 fuel pump gfb fpr turbo side intake Valve springs oil pump gears Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 21/05/23 02:54 AM Share Posted 21/05/23 02:54 AM Change to E85 and add a couple of psi. Literally only a fuel change and a tune should be all you need. Link to comment Share on other sites More sharing options...
Jarednz New Member 7 Member For: 1y 4m 6d Posted 21/05/23 03:05 AM Author Share Posted 21/05/23 03:05 AM Sweet as, cheers for the reply. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 21/05/23 03:14 AM Share Posted 21/05/23 03:14 AM Get a trans tune done too, it'll need it to stay alive for the long term Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,370 Member For: 5y 25d Gender: Male Location: Perth, WA Posted 22/05/23 12:53 AM Share Posted 22/05/23 12:53 AM (edited) 22 hours ago, Jarednz said: So have recently tuned my fg G6et made 380kw (16psi) on 98. Was curious what else I would have to do to make more power 400-450kw, the current mods are as follows 6boost manifold 4” exhaust gtx3584rs turbo pulsar intercooler 45ml external gate 1000cc injectors wahlbro 450 fuel pump gfb fpr turbo side intake Valve springs oil pump gears Kinda amazed you haven't reached that figure with this setup? Do you have any info on the last tune? Why did they stop at 380kw? Head studs maybe? I don't believe you need them to get to 400kw, but I'd recommend getting them done just for piece of mind really. 450kw you're pushing the limits on 98, I'd switch to e85 if you're chasing more than 400-410kw I'd say Have a read through some threads in the "400+ Club" to see what other peoples setups were to achieve 400+kw. https://www.fordxr6turbo.com/forum/forum/152-400-club/ Shameless plug of mine 😏 Edited 22/05/23 12:55 AM by biddie_fiddler 450kw probably requires e85 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 22/05/23 01:33 AM Share Posted 22/05/23 01:33 AM You won't make much over 400rwkw on 98 unless you have a large turbo, cams and head work. A hub dyno will give 10% inflated numbers but at the end of the day it's just a different way of measuring the same thing. 380rwkw is the upper safe limit of 98 for the most part. Link to comment Share on other sites More sharing options...
