kimberly915 New Member 2 Member For: 1y 27d Posted 29/03/23 05:40 AM Share Posted 29/03/23 05:40 AM I am new here, learned many information from this place .😃 I bought an oil feed line on eBay, but the banjo bolt couldn't be screwed into engine block side. Seller told me the thread size is M14, but it seemed to be different with mine. The car is Ford Falcon BF Sedan 4.0 I XR6 Turbo. Is there any different with engine block thread size? car / year? Link to comment Share on other sites More sharing options...
kimberly915 New Member 2 Member For: 1y 27d Posted 31/03/23 03:10 AM Author Share Posted 31/03/23 03:10 AM No one knows the thread? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 31/03/23 03:22 AM Share Posted 31/03/23 03:22 AM (edited) When you buy an oil feed the banjo fitting takes the place of the stock steel line. The only bit that screws into the block is the original fitting, which is shown in the picture below. The banjo fitting goes over that, then the line attaches to the banjo fitting, then you fit the switch on then end to seal it up. Because you are fitting an aftermarket filter you can remove the stock turbo oil feed line filter, which is under the cir-clip in the picture. Â Edited 31/03/23 03:23 AM by Puffwagon Link to comment Share on other sites More sharing options...
