HardrfastrturboBF New Member 2 Member For: 1y 7m Posted 24/09/22 01:53 PM Share Posted 24/09/22 01:53 PM I have just turned my 07 BF ute turbo ,had a whole damaged car that I took motor box wiring and ECU from which made it easier. But now I have just learnt I should have swapped the BCM from the other vehicle ,I had to have a mechanic hook up to my ECU and have a program down loaded to make it all hook up right it is now going mint . NOW the only problem I have is I dont have a code for my radio so it wont turn on the AC and heater work but no display ,I can turn it on with a hack but only lasts 5 minutes then turns off . How do I find code or get it going. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 24/09/22 11:50 PM Share Posted 24/09/22 11:50 PM You need the BEM from the original vehicle's ICC (the box that all of the looms plug into at the bottom of the ICC). Or your BEM coded to be exactly the same as the one from the original vehicle. Link to comment Share on other sites More sharing options...
