Djov132 New Member 7 Member For: 2y 12d Posted 16/07/22 10:55 PM Share Posted 16/07/22 10:55 PM Car Is having boosting issues especially when cold new plugs new coils, when driving it seems that the revs get stuck and a popping noise can be heard from the turbo side but then hits boost straight after that. Car has a few mods bigger fuel pump, injectors, exhaust, external wastegate, side turbo intake, after market intercooler, and a screamer and is also on 12 psi of boost would love some advice to lead me to the right direction cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 16/07/22 11:04 PM Share Posted 16/07/22 11:04 PM How loud is the popping? if it's more of a "bang" then it'll be some sort of ignition getting back to the turbo intake (unlikely)... if it's a tinkling popping sort of sound, it might be knock, which is worse for your engine internals. I'd get it run up on a dyno to check air-fuel ratio's and the relevant tune run-up. Link to comment Share on other sites More sharing options...
cat007 Member 234 Member For: 5y 7m 21d Posted 16/07/22 11:06 PM Share Posted 16/07/22 11:06 PM Check with your tuner? Link to comment Share on other sites More sharing options...
Djov132 New Member 7 Member For: 2y 12d Posted 16/07/22 11:16 PM Author Share Posted 16/07/22 11:16 PM @k31th you can definitely hear the popping noise it happens 1 or 3 times while it’s hitting boost and with just hold the revs and won’t go anywhere then 5 seconds later it would boost hard. So you think it’s a tune issue? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 16/07/22 11:18 PM Share Posted 16/07/22 11:18 PM it's hard to know... it could be a mechanical issue like a sticky wastegate or something, but a dyno run will help diagnose it. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 17/07/22 02:00 AM Share Posted 17/07/22 02:00 AM More than likely it's boost spiking and hitting boost cut when it comes onto boost. Easy to check and easy to fix. Link to comment Share on other sites More sharing options...
Djov132 New Member 7 Member For: 2y 12d Posted 17/07/22 02:12 AM Author Share Posted 17/07/22 02:12 AM @Puffwagon how do I checked this or do I take it to the tuner Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 17/07/22 02:46 AM Share Posted 17/07/22 02:46 AM Haha what I should have said is it's easy for the tuner to check and fix for you. Link to comment Share on other sites More sharing options...
