Roadrunner New Member 4 Member For: 6y 11m 7d Posted 12/05/22 06:10 AM Share Posted 12/05/22 06:10 AM I've searched and googled to death without being able to find an answer. I have a set of FG cams to replace the well worn cams in my BA turbo. Is the changing of these a simple in/out replacement and magic happens or will the car need a tune following? I run a haltech plug in if that makes any difference. Anything else I need to be aware of? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 2m Gender: Male Location: South Australia Posted 12/05/22 06:12 AM Share Posted 12/05/22 06:12 AM Give us some more info, clearly you aren't running a haltech in an otherwise stock car. Link to comment Share on other sites More sharing options...
Roadrunner New Member 4 Member For: 6y 11m 7d Posted 12/05/22 06:38 AM Author Share Posted 12/05/22 06:38 AM Factory ba turbo, it's not stock, around 350rwkw. Injectors, E85, dump pipe, exhaust, bigger intercooler, etc etc. Cam lobes are badly worn and I have FG cams here. Just trying to ascertain as to whether I need to allow dyno time or just run it. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 2m Gender: Male Location: South Australia Posted 12/05/22 06:56 AM Share Posted 12/05/22 06:56 AM If your cams are that farked then the phasers are probably rooted too. I'd want to make sure that there isn't any hectic cam error before sinking the boot in. The cam position dictates fueling so it's important it all works correctly. If you've got a wideband hooked up then run it and make sure it's under 12.5:1 at full load. If not then get it checked. It's only $150 for a few power runs and that'll tell you if it needs a tune or not, and also indirectly whether the cam timing is somewhat passable. But yeah you can just chuck them in and drive it. Link to comment Share on other sites More sharing options...
Roadrunner New Member 4 Member For: 6y 11m 7d Posted 12/05/22 08:34 AM Author Share Posted 12/05/22 08:34 AM 1 hour ago, Captain Yeah Nah said: But yeah you can just chuck them in and drive it. thank you. cams are scored but car runs fine as is. I was just going to swap them while I was doing other work Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 2m Gender: Male Location: South Australia Posted 12/05/22 08:41 AM Share Posted 12/05/22 08:41 AM No worries mate, happy to help Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,240 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 12/05/22 08:53 AM Share Posted 12/05/22 08:53 AM yeah, FG cams will run fine, but no point installing them if you're not going to get your tune adjusted to suit them, imho. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 2m Gender: Male Location: South Australia Posted 12/05/22 09:17 AM Share Posted 12/05/22 09:17 AM The only thing that adding cams will do is lean it out a bit and maybe frig with the boost control a bit. There is no magic power unlock by tuning fg cams vs just chucking them in. Chuck em in, check the afr and boost control then send it. Link to comment Share on other sites More sharing options...
Roadrunner New Member 4 Member For: 6y 11m 7d Posted 12/05/22 09:45 AM Author Share Posted 12/05/22 09:45 AM The cars tuned for closed loop boost and afr so will be safe enough for a start up and some track tuning. Getting it to a dyno is a bit of a task when it's not registered. Link to comment Share on other sites More sharing options...
