tofski Member 25 Member For: 12y 18d Posted 24/11/22 10:00 AM Share Posted 24/11/22 10:00 AM Not sure why that occurred, motor is running full copper 40thou head gasket with oringed block and head . Also 14mm head studs down to 150ftlb . Been fine after that run so see what happens. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 24/11/22 10:23 AM Share Posted 24/11/22 10:23 AM Copper and MLS gaskets reseal after an incident like that so it will be fine in that respect, however it 's worth looking into. See how much timing is in it, if there's heaps more than 20 degrees it would answer at least part of that question. Was the block decked with 150lbft on the torque plate? Anyhow I'm sure you'll sort it out, you don't get a power figure like that from nowhere. Link to comment Share on other sites More sharing options...
tofski Member 25 Member For: 12y 18d Posted 24/11/22 10:50 AM Share Posted 24/11/22 10:50 AM When that happened we pushed to see what the turbo would do and even after that no probs even with more pulls ,re the timing I'll have to ask the tuner , that said I won't be pushing the limits of the turbo all the time hard enough to hook up with 500kw on the street. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 24/11/22 10:54 AM Share Posted 24/11/22 10:54 AM Maybe it wasn't pushing combustion gas through the head gasket, maybe it was just hot and pushed water past the cap. Seems reasonable enough. Haha keep it turned up man, just use the right foot to keep it hooked up 1 Link to comment Share on other sites More sharing options...
tofski Member 25 Member For: 12y 18d Posted 24/11/22 11:08 AM Share Posted 24/11/22 11:08 AM Don't think it pushed past the gasket as it was doing 40psi same motor setup on c16 when it was the ETM f6 back in the day , I think the pwr expansion tank and cap are a bit dodgy , Gonna still push the limits 👍 2 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 24/11/22 11:12 AM Share Posted 24/11/22 11:12 AM Hell yeah brother Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,370 Member For: 5y 27d Gender: Male Location: Perth, WA Posted 25/11/22 12:06 AM Share Posted 25/11/22 12:06 AM Woulda sh*t myself if I saw my car on a dyno push out a puff of whatever that was 🤣🤣🤣 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 25/11/22 12:24 AM Share Posted 25/11/22 12:24 AM 17 minutes ago, biddie_fiddler said: puff Link to comment Share on other sites More sharing options...
tofski Member 25 Member For: 12y 18d Posted 25/11/22 06:42 AM Share Posted 25/11/22 06:42 AM 6 hours ago, biddie_fiddler said: Woulda sh*t myself if I saw my car on a dyno push out a puff of whatever that was 🤣🤣🤣 Not worried , done a co2 coolant test right after the run and come up negative . Whatever happens now only time will tell , either way will be fun in the process. Link to comment Share on other sites More sharing options...
Fox Body Barra New Member 5 Member For: 2y 3m 6d Posted 25/11/22 02:55 PM Share Posted 25/11/22 02:55 PM This is excellent. I'm trying to size a turbo for 1000whp that streetable as well. I was considering a g42 but maybe a g40 1050 is the way to go. 16 hours ago, tofski said: Not worried , done a co2 coolant test right after the run and come up negative . Whatever happens now only time will tell , either way will be fun in the process. what rpm do you start seeing boost by? This looks like an ideal street setup. This is a 1.06 exhaust housing? Link to comment Share on other sites More sharing options...
