SydCrazi Member 141 Member For: 13y 5m 7d Gender: Male Location: NSW Posted 23/12/21 09:13 PM Share Posted 23/12/21 09:13 PM Hi Guys and Gals, Just wondering if anyone has had experience in upgrading just their compressor wheel. I'm seeing a lot of adds (and they are wearing me down to purchase point, but I will continue resistance) where I can upgrade from 7 blade wheel to billet 11 blade wheel with reverse tip small blades for more puff up top? Seems to me you would only upgrade if you are getting close to maxing out the psi of existing setup, I don't see how efficiency gains would warrant such an exercise. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,124 Member For: 9y 2m 24d Gender: Male Location: South Australia Posted 24/12/21 01:00 AM Share Posted 24/12/21 01:00 AM I've upgraded a stock ba/bf 3582 to a gtx comp wheel and 0.7 housing. There was a little bit of difference and the car felt better with slightly more lag. I'd imagine just a comp wheel swap on it's own would do 2/3s of fark all. If you're getting to the point of buying something, get a pulsar 3584rs. It'll be a decent jump from a stock turbo, is nice and cheap and will support plenty of power for many mods to come. Link to comment Share on other sites More sharing options...
SydCrazi Member 141 Member For: 13y 5m 7d Gender: Male Location: NSW Posted 24/12/21 01:28 AM Author Share Posted 24/12/21 01:28 AM (edited) @Puffwagon 2/3rds of fark all Ahhh got to love that metric... Haha.. Had a feeling it'd be a Beez 🐝 d!ck difference.. I'll just upgrade whole Turbo if need be, may as well go external wastegate and screamer too while I'm at it 😁🤟 Edited 24/12/21 01:28 AM by SydCrazi Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,124 Member For: 9y 2m 24d Gender: Male Location: South Australia Posted 24/12/21 01:47 AM Share Posted 24/12/21 01:47 AM Yeah man I'd rather a big upgrade over a smaller one. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,299 Member For: 16y 13d Gender: Male Location: Melbourne Posted 24/12/21 04:00 AM Share Posted 24/12/21 04:00 AM A guy back in the day upgraded the stock GT3582R from a .5 front cover (stock) to a .7 front cover and made enough power to just barely into the high 9's with all of the relevant supporting mods. That was wringing the turbo's neck, of course, but still, a worthwhile upgrade in certain circumstances. Link to comment Share on other sites More sharing options...
Slowxr6t Member 516 Member For: 5y 4m 19d Location: New zealand Posted 27/12/21 10:59 PM Share Posted 27/12/21 10:59 PM @Puffwagondid you go to 11 blade gen 1 comp wheel or 10 blade gen 2 wheel? I'm thinking of buying a gen 2 supercore. Or getting my gt3582r comp housing bored out to fit either gen 1 wheel or gen 2 wheel. I havnt seen any real life gen 1 vs gen 2 comparisons apart from garrett rhetoric saying gen supposed to be 10 % better. Aus Automotive on YouTube got a gen 1 put on his g6et and it looks like it spools hard out. Link to comment Share on other sites More sharing options...
SydCrazi Member 141 Member For: 13y 5m 7d Gender: Male Location: NSW Posted 27/12/21 11:15 PM Author Share Posted 27/12/21 11:15 PM @Slowxr6t to quote @Puffwagon apparently changing the wheel does 2/3rds of fark all. However seeing as your Turbo is out and getting worked on, you may as well. I've been led to believe blade count is not that important it's overall design. Hopefully you can get some real world feedback and go with that. Also look into reverse fins etc and their effect. Good luck and please post results 🤟 Link to comment Share on other sites More sharing options...
Slowxr6t Member 516 Member For: 5y 4m 19d Location: New zealand Posted 27/12/21 11:44 PM Share Posted 27/12/21 11:44 PM @SydCraziI already have .7 comp cover on my gt3582r. I don't know what it would cost to hybridize my turbo, probably a grand, everything is a grand, I might just put that money towards a supercore. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,124 Member For: 9y 2m 24d Gender: Male Location: South Australia Posted 27/12/21 11:47 PM Share Posted 27/12/21 11:47 PM On 24/12/2021 at 7:43 AM, SydCrazi said: upgrading just their compressor wheel. You said only the compressor wheel, nothing about the compressor housing. This means it's the same size hence doing fark all. 47 minutes ago, Slowxr6t said: Did you go to 11 blade gen 1 comp wheel or 10 blade gen 2 wheel? I used the gen 1 wheel as the gen 2 wasn't out then, which is bigger than the stock Ford wheel and makes more difference in power. I also had to get my gt housing machined to fit. The gen 2 wheel is much bigger at 66mm, makes much more power and comes on roughly 800rpm later. I actually bought a gen 2 supercore when they first came out and fitted that to my ported and flapperised Ford turbine housing. On E85 I made 503awkw at 23psi in my territory. I never ran the gen 1 setup on E85 so can't compare numbers but I think it would max out in the low to mid 400's. Link to comment Share on other sites More sharing options...
SydCrazi Member 141 Member For: 13y 5m 7d Gender: Male Location: NSW Posted 27/12/21 11:49 PM Author Share Posted 27/12/21 11:49 PM My bad. Got trigger happy on my response. Impressive figures Link to comment Share on other sites More sharing options...
