It is I Member 37 Member For: 2y 6m 4d Posted 06/12/21 11:19 PM Share Posted 06/12/21 11:19 PM When I plug in the OBDii+ sensor, two things happen: 1. Traction Control turns off and a warning comes on saying DSC fault 2. When I get on boost, the boost is cut completely. If I turn off the car and unplug the sensor, all works fine again. My car is tuned so I'm thinking that the parameters are all different to factory, causing issues. So for example with 2, when it exceeds the factory set boost, it cuts boost. But an OBDii+ sensor should surely not cause that? And it's not going into limp mode, just cutting boost. Any ideas? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 07/12/21 12:05 AM Share Posted 07/12/21 12:05 AM It's normal for errors to be shown when some stuff is plugged into the obd port. 44 minutes ago, It is I said: If I turn off the car and unplug the sensor, all works fine again. There's your fix. Easy! Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 07/12/21 12:34 AM Share Posted 07/12/21 12:34 AM yep, sounds like a dodgy OBD2 thingo. Replace it. Link to comment Share on other sites More sharing options...
It is I Member 37 Member For: 2y 6m 4d Posted 07/12/21 12:39 AM Author Share Posted 07/12/21 12:39 AM Ok great, thanks guys Link to comment Share on other sites More sharing options...
