Certifiedxr6t New Member 4 Member For: 2y 4m 30d Posted 28/11/21 04:02 PM Share Posted 28/11/21 04:02 PM Hello everyone, This is what I have in mind! Let me know anything else I forgot? Ford Falcon FG XR6T Mod List. Ultrex 4 Inch Turbo Back Exhaust - https://www.ultrex.com.au/ford-falcon-sedan-fg-xr6t-fpv-f6-4-inch-turbo-back~5793 $1500 Crow Cams Valve Springs - https://www.tiperformance.com.au/products/crow-cams-ba-bf-fg-falcon-xr6-barra-4l-dohc-valve-spring-retainer-kit-vtkba6t-24/ $429 Process West Stage 2 Intercooler - https://processwest.com.au/product/191/PWFGIC02-Stage-2-Intercooler-Kit-suits-Ford-Falcon-FG $1965 Bosch 1000cc Injectors - https://antzperformance.com.au/product/6-x-bosch-1000cc-110lb-injectors-0280158040-suit-fg-xr6-turbo-e85-compatible/ $550 Pulsar GTX3584 Turbo - https://www.pulsarturbo.com.au/products/pulsar-turbo-gtx3584rs-gen2-turbocharger?variant=37219636052118 $1000 Walbro 525 Fuel Pump - https://www.golebysparts.com.au/products/walbro-525lph-fuel-pump?variant=39443993166011 $215 Stage 1 Tune Monster Torque - https://www.monstatorque.com.au/ford-fpv/fg-xr6t/ $1950 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 28/11/21 09:34 PM Share Posted 28/11/21 09:34 PM That'll get you way over 300 if you want it. You can get there with an FG XR6T with just a catalytic converter, injectors, fuel pump and a E85 tune even 98 will push close to 300 with those mods Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,370 Member For: 5y 21d Gender: Male Location: Perth, WA Posted 29/11/21 12:15 AM Share Posted 29/11/21 12:15 AM I have a 255lph fuel pump, stock exhaust, stock springs and mt stage one and made over 300kw, so with everything listed you'll definitely make over 300kw. Get the pw piping kit too if you haven't, I don't imagine installing the IC with the stock piping will connect up very well. Why are you looking upgrading the turbo? You'll need an external wastegate setup with that chosen turbo, about $1500 through mt. My brother has that turbo, its way more laggy than the stock one, and will put you closer to 350kw mark. Also, MT stage 1 includes injectors so you don't need to buy them separately 525 fuel pump requires bigger gauge wiring than stock. You will fry your stock wiring if you connect it straight up, seen this on the forums and on FB multiple times in the past. Easy to upgrade though If I'm not mistaken, you'd also need to do some pressure relief mod thing to the factory fuel hanger and you'd likely need a fpr too. Link to comment Share on other sites More sharing options...
