R ichard Member 75 Member For: 3y 27d Posted 24/11/21 09:39 PM Share Posted 24/11/21 09:39 PM Hiya’ just Noticed a week or two ago that I’m leaking just below the thermostat, can I drain the fluid and try undo the bolt and redo it up to see if it stops it leaking? also thinking about replacing the thermostat, car has just done 180000km so was planning on cleaning out all the radiator fluid Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 24/11/21 10:08 PM Share Posted 24/11/21 10:08 PM You can do a flush and repair, but just re-doing it up is unlikely to fix your core problem. You probably need to clean up the connection points and perhaps replace the bit of flexible pipe. Link to comment Share on other sites More sharing options...
R ichard Member 75 Member For: 3y 27d Posted 24/11/21 11:45 PM Author Share Posted 24/11/21 11:45 PM hiya, sorry 1st photo wasnt very clear have a look at this one its not the flexible pipe Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 24/11/21 11:59 PM Share Posted 24/11/21 11:59 PM Change your coolant every 20,000km. You gotta remove the pipe from the thermostat housing, clean the fark out of the pipe and the thermostat housing, replace the green o-ring that seals the pipe to the thermostat housing and reassemble it. 1 Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,367 Member For: 4y 11m 28d Gender: Male Location: Perth, WA Posted 25/11/21 12:26 AM Share Posted 25/11/21 12:26 AM One of the flaws of these motors, that fkn o-ring 🤣🤣🤣 Link to comment Share on other sites More sharing options...
R ichard Member 75 Member For: 3y 27d Posted 25/11/21 01:29 AM Author Share Posted 25/11/21 01:29 AM 1 hour ago, Puffwagon said: Change your coolant every 20,000km. You gotta remove the pipe from the thermostat housing, clean the fark out of the pipe and the thermostat housing, replace the green o-ring that seals the pipe to the thermostat housing and reassemble it. Is that some what easy to do? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 25/11/21 01:38 AM Share Posted 25/11/21 01:38 AM Yes, very easy. Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,367 Member For: 4y 11m 28d Gender: Male Location: Perth, WA Posted 25/11/21 01:56 AM Share Posted 25/11/21 01:56 AM @R ichard From the workshop manual, clearly shows where the O-ring is located Pretty sure that step 2 is referring to item 3 in the table. If I'm not mistaken, the O-ring is part of the heater section of the cooling system. though, doesn't really matter what its for, it just needs to be replaced periodically. Personally, I do when it starts leaking but preventative maintenance, like what puff recommended, is a better option. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 25/11/21 02:27 AM Share Posted 25/11/21 02:27 AM The only reason I suggested to replace the o-ring is because it is leaking. I wouldn't call it a maintenance item and like you, I'd only fix it when it leaks. Even if it is apart for work, the old o-ring is going back in until it leaks. Link to comment Share on other sites More sharing options...
R ichard Member 75 Member For: 3y 27d Posted 25/11/21 07:26 AM Author Share Posted 25/11/21 07:26 AM cheers guys will look into this over the weekend, would I need to go to ford to get new o rings or does supercheap/repco have them? Link to comment Share on other sites More sharing options...
