AlanC New Member 2 Member For: 6y 5m 21d Posted 11/11/21 10:35 PM Share Posted 11/11/21 10:35 PM Greetings all. Occasionally my engine light comes on so I bought one of those scan tools so see what I could see. P0340: Camshaft Position Sensor A Circuit error comes up. So I assume I'll need to replace the camshaft position sensor - can anyone tell me exactly where it is please? I can't seem to find a decent photo to use as a guide. BF MK11 XR6T. Thanks.... Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 11/11/21 11:38 PM Share Posted 11/11/21 11:38 PM They are separate to the camshaft phasers (which are behind the camshaft sprockets underneath the rocker cover, so it's not these, but in the same area) and they point at 3+1 wheel on the front of the cam sprockets which indicates position to them. You'll find them easy enough. They also look like this (this one is an exhaust-side one). Make sure to buy one that matches the size/shape/position of your faulty one when you diagnose it as the two sides are different. You might not also have timing problems, so replacing the sensor might not fix the issue completely. Good luck. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 12/11/21 01:09 AM Share Posted 12/11/21 01:09 AM 1 hour ago, k31th said: they point at 3+1 wheel on the back of the camshaft sprockets FTFY They fit in each side of the head closest to the firewall. Remove the electrical plug, undo the bolt with a 7mm socket, spray some crc or whatever on it and have fun pulling it out cos they are usually stuck. Some twisting and gentle levering with a small screwdriver does the trick. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 12/11/21 01:12 AM Share Posted 12/11/21 01:12 AM which side is the "back of the camshaft" lol Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 12/11/21 01:34 AM Share Posted 12/11/21 01:34 AM The same as the back of the car Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 12/11/21 01:46 AM Share Posted 12/11/21 01:46 AM I knew I'd forgotten a crucial detail... thanks... I'm not sure why I was remembering them being at the front, probably a different engine I was remembering. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 12/11/21 01:54 AM Share Posted 12/11/21 01:54 AM Maybe you were thinking of the cam solenoids? Anyhow it's all good...you know what they say...if you want to find out the answer to your question, post the wrong info on the internet and someone will be sure to correct you! Link to comment Share on other sites More sharing options...
AlanC New Member 2 Member For: 6y 5m 21d Posted 12/11/21 10:31 AM Author Share Posted 12/11/21 10:31 AM Thanks guys.. I just wasn't sure where to look. Cheers Link to comment Share on other sites More sharing options...
