Nathan017 Member 31 Member For: 2y 7m 10d Posted 10/10/21 04:30 AM Share Posted 10/10/21 04:30 AM I have my drivers indicator randomly stopping and start flashing fast like a bulb is blown - however none are blown and they all work. this only happens on the drivers side, iv done some reading about changing the indicators relay but I cant seem to locate it in any fuse diagrams or any previous threads? can anyone share any info to help so annoying and potentially dangerous. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,290 Member For: 16y 8d Gender: Male Location: Melbourne Posted 10/10/21 05:41 AM Share Posted 10/10/21 05:41 AM your owners manual has a fuse/relay diagram. Link to comment Share on other sites More sharing options...
Nathan017 Member 31 Member For: 2y 7m 10d Posted 10/10/21 05:51 AM Author Share Posted 10/10/21 05:51 AM checked all the diagrams and doesn’t state a relay for indicators Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 27d Gender: Male Location: Canberra ACT Posted 10/10/21 06:57 AM Share Posted 10/10/21 06:57 AM I might be wrong, but I reckon in modern cars where body electrics are controlled by a computer, there wouldn't be a separate flasher unit - the computer would just send a rapid on/off signal to a standard relay. Link to comment Share on other sites More sharing options...
Nathan017 Member 31 Member For: 2y 7m 10d Posted 10/10/21 07:06 AM Author Share Posted 10/10/21 07:06 AM hmmm leaves me stuck as to why this is happening, bizarre enough when the car isn't running it doesn't cause any issues as I just realised when I tried swapping bulbs around to see if there was any bulb on it is way out potentially. Link to comment Share on other sites More sharing options...
Nathan017 Member 31 Member For: 2y 7m 10d Posted 12/10/21 08:10 AM Author Share Posted 12/10/21 08:10 AM managed to narrow this down to the rear LED tail lamps fitted , unplugged the side causing the issue , and when car realises its off it still flickers but fast, rather then when its plugged it and it malfunctions all indicators stop completely on that side . noticed a few LEDS out on each of the panels so im thinking of replacing them completely to see if it is the problem. I noticed resistors underneath , x 2 on each side to ramp the volts up, could out LEDs cause drop in voltage therefor tripping the computer Link to comment Share on other sites More sharing options...
