Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 02/10/21 12:15 AM Share Posted 02/10/21 12:15 AM Loosen the bearing to body bolts and do them up again with no pressure on the bearing. If they are done up before the diff and trans ends, it will load the bearing one way or the other. Link to comment Share on other sites More sharing options...
Nathan017 Member 31 Member For: 2y 7m 17d Posted 02/10/21 12:31 AM Author Share Posted 02/10/21 12:31 AM When you say loosen the bolts to the body, what am I looking to accomplish when the slack has been taken off the centre bearing. Are you saying the bearing will re-position it’s self Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 02/10/21 01:36 AM Share Posted 02/10/21 01:36 AM Yep that's it. Link to comment Share on other sites More sharing options...
Nathan017 Member 31 Member For: 2y 7m 17d Posted 02/10/21 02:09 AM Author Share Posted 02/10/21 02:09 AM iv just done that and then removed the diff shims as I feel like they made it worse . went around the block seams better, although I can still mildly feel it . should I do it again now the diff shims are removed ? this may sound like a stupid question, but looking under the car the from the transmission to the center bearing through to the diff , should the center bearing onwards have a slight angle in the tail shaft or should it be completely straight ? as makes me wonder do people add washers to the centre bearing bolts to drop it at all as when I loosen the centre bearing it dropped about 15mm worth before it had no strain . sorry for your the essay, just so over this vibration that im really getting fed up diagnosing this Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 02/10/21 02:43 AM Share Posted 02/10/21 02:43 AM 33 minutes ago, Nathan017 said: should I do it again now the diff shims are removed ? Sure why not?! At this stage you've covered most of what to do. Link to comment Share on other sites More sharing options...
Nathan017 Member 31 Member For: 2y 7m 17d Posted 02/10/21 08:03 AM Author Share Posted 02/10/21 08:03 AM Ahhhhhh no luck. So over this issue, its making me not want to drive it anymore. I honestly am baffled as to why it's doing this . Is there anything else that could be causing this ? even gave the engine a few revs with the break to see if there was any engine mount issues. Link to comment Share on other sites More sharing options...
Nathan017 Member 31 Member For: 2y 7m 17d Posted 03/10/21 02:37 AM Author Share Posted 03/10/21 02:37 AM iv just had a look online for new rubber support saddle insulators and iv realised my rear leafs only have the top mount saddle not the bottom, makes me wonder if this would cause vibration as it’s basically metal on metal contact , and since it’s been my first observation on a vehicle with leafs I haven’t known any different Link to comment Share on other sites More sharing options...
