Do original fg 2010. Xr6 turbos have a grey rocket cover
Bazza11
  • Member For: 3y 1m 22d
I’m looking to buy this fg turbo and noticed that it had a grey rocket cover which unusual to me because usually they are only on the n/a models. I was wondering if they also came with the turbos or if it has been turbo converted
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 5d
no, the stock XR6T's all have a red rocker cover... it's highly likely it has been turbo-converted or somebody has thrown a cheap N/A engine in after grenad'ing the original one.
  • Site Developer
just ask to see the engine number (on the actual engine block under the exhaust manifold on the sump) and compare it to the one on the vehicle identification plate and if it's different, you'll know the engine has been swapped... it sounds too dodgy to me, based on your description.
  • Member For: 3y 1m 21d
No need man... grey rocker cover means it's either had an engine swap or a rocker cover swap (which is unlikely) check the engine numbers.... if it started life as a turbo and now has a NA engine in it.... I wouldn't be buying unless it's dirt dirt cheap..
its more likely to be an NA which has had turbo gear thrown onto it...
Edited by TRYME
