Map sensor ba xr6 t
jas98
  • Member For: 11y 9m 2d
Hi. Wanting a new map sensor. It's a ba xr6 turbo. I have come across the following which I have seen is suitable for the car etc. But wanting to make sure.
As I understand the factory one is a 2 bar and this one I've linked is a 2.5 bar. Would that matter?
https://www.bosch-motorsport-shop.com.au/t-map-sensor-2.5-bar-130-deg-c
The one Bosch themself recommend and also supercheap says there upwards of 250 plus. But a few places has said this one is the factory equivalant
Thanks. I can't find the specs on said sensor. However everywhere I look shows that number being suited for the car ...only a couple places don't lost it like supercheap but they lost other brands for it.
Also I was wrong. It seems Bosch them selfs don't make the one they recommended anymore (says no longer available) so I'm guessing this is why this other number has come along.
Thanks...wow ford wants 280 here. I'll ring another dealer
Although I was under impression that the ba bf tuebomones are different to the FG turbo?
Different pinned and connector?
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 15d
I believe that "Turbo" ones are the same across models, but the N/A is different to Turbo in terms of pin arrangement.
Thanks. Was told there different and can't be used without tuning to suit. Also connections different....but maybe I was mistaking it with the n/a with the connections
  • 1 month later...
