izzy652 New Member 2 Member For: 2y 7m 21d Posted 03/09/21 12:14 PM Share Posted 03/09/21 12:14 PM Hi All, Just picked up a manual XR6T FGX. Want to do a full service on the car including the gearbox. The service guide specifies using 3.85L of Dexron III oil. Going through the forums, people have suggested using a Penrite ProGear 70W-75 Sin or Castrol Transmax Z. Further, some have suggested adding 4.85L to remove the rollover noise and smoother shifts. Most of these posts are from 2012 or earlier. Just wanted to know what is common to use in the TR6060 transmissions and what people have had success with. Last thing I want to do is too add too much fluid or the wrong type and do some damage. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 04/09/21 01:11 AM Share Posted 04/09/21 01:11 AM yes, the parameters are similar for the TR6060 as they are for the T56. You can use dexron 3 if necessary but those mentioned are better for noise reduction... take out the "reverse lockout" switch and fill through there until it dribbles over the side and you'll find it adds somewhere around 4.8L. Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 25d Posted 04/09/21 02:32 AM Share Posted 04/09/21 02:32 AM Hey mate, you just have to be careful with what you use due to the synchro material used in the TR6060. There are plenty of synthetic fluids out there that meet or exceed DexIII specifications Link to comment Share on other sites More sharing options...
izzy652 New Member 2 Member For: 2y 7m 21d Posted 05/09/21 02:12 AM Author Share Posted 05/09/21 02:12 AM Thanks for the reply guys. I've gone with Penrite AFT FS purely based that its fully synthetic and meets DEX 3 standards. I had read that a couple of other guys have had issues with sticky gears with the ProGear stuff and Mal didn't recommend Transmax. I'll chuck it in this week and see how it goes. Link to comment Share on other sites More sharing options...
