Typhoon Member 564 Member For: 19y 7m Gender: Male Posted 28/09/21 11:39 AM Share Posted 28/09/21 11:39 AM Wont be the cam caps, wont be the OCVs. Disable the VCT in ESP and see if that helps. Can the VCT maintain target at all or is it just when the oil is hot? What oil temps are you seeing? Does it only stall when hot after a WOT? Is the engines oiling system still stock or has oil flow to the head been restricted? Noise at idle is consistent with a phaser struggling to work, a blocked oil gallery can also cause this. Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 24d Posted 28/09/21 09:40 PM Share Posted 28/09/21 09:40 PM I'm not sure man, my tuner is working it out. They've been really good talking to all the right people to find the problem, no hint of trying to mask it by just locking the timing. Phasers are being replaced. Oiling is stock, and the right weight oil is being used for the clearances. Apparently the intake cam is all over the place on idle when it's hot, and it's noisy on idle. Oil galleries should be ok, its had the run in oil changed out already. They've done a very controlled and deliberate run in process, which is good to see. Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 7m Gender: Male Posted 29/09/21 10:36 AM Share Posted 29/09/21 10:36 AM Its may actually be a phaser then. If it doesn’t solve the issue then you wont have many options left other then locking the VCT to a fixed position. I don’t see it as masking the problem, it is what it is. Modified cars! 2 Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 24d Posted 05/10/21 09:12 AM Share Posted 05/10/21 09:12 AM The saga continues. Phasers apparently fixed the timing issue, but it's still noisy. So lifters are now being changed out Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 7m Gender: Male Posted 05/10/21 06:28 PM Share Posted 05/10/21 06:28 PM Are you running a solid or hydraulic tensioner? Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 24d Posted 05/10/21 09:24 PM Share Posted 05/10/21 09:24 PM Just the standard hydraulic man Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 7m Gender: Male Posted 08/10/21 02:31 AM Share Posted 08/10/21 02:31 AM Any updates Tom? Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 24d Posted 08/10/21 06:58 AM Share Posted 08/10/21 06:58 AM No man, it'll get new crow lifters next week. Hopefully it takes care of the noise. It's a bit frustrating when the head was fully rebuilt. Why would you throw 200k km lifters back in? My tuner is charging the engine builder for the labour, which is good Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 08/10/21 07:32 AM Share Posted 08/10/21 07:32 AM 28 minutes ago, Tom Tucker said: Why would you throw 200k km lifters back in? If you are asking this you'd be plum shocked at some of the sh*t that "workshops" do. Even with new lifters, there's more to it than just chucking them in and calling it a day. Let us know how much quieter it gets, as I'm interested in the outcome. Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 24d Posted 08/10/21 07:57 AM Share Posted 08/10/21 07:57 AM Yeah, you're right. I'd have no idea if the titanium retainers I bought were actually used... Link to comment Share on other sites More sharing options...
