El Andrew Gold Donating Members 2,019 Member For: 8y 11m 26d Gender: Male Location: Canberra ACT Posted 05/08/21 03:11 AM Share Posted 05/08/21 03:11 AM Any decent should be able to - it's a little fiddly but nothing complex.Sorry that's what I was trying to explain above - that mod DOES NOT unlock extra power. It helps you limit the boost so you don't get unintended spikes. It doesn't increase your maximum boost or power levels.Baby turbo is going to max around 309-320kw. For $850 or so you can get a Pulsar GTX3576 gen 2 equivalent supercore to bolt up to your existing rear housing. That will go more power but will definitely need the flapper mod.Edit: weird post delay, but same-same 1 Link to comment Share on other sites More sharing options...
FGeorge Member 79 Member For: 2y 10m 17d Posted 05/08/21 03:23 AM Author Share Posted 05/08/21 03:23 AM I feel like the jigsaw puzzle is coming together now. I imagine that bigger core would mean the boost comes on a little later. Is there a big difference? I like how quickly the baby turbo spools when driving around the place Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 13d Gender: Male Location: Townsville Posted 05/08/21 04:17 AM Share Posted 05/08/21 04:17 AM OP: you play- you pay. Accept this right from the outset or don't start down the modifying path. Its gonna cost more than you think in the end anyway....Yes but as I said, everyone gets the same feeling regardless of what it is. New car, new house, new state, job etc etc... Will it? Your gate is pegged open. It will hit whatever it wants depending on conditions. Boost limited is not boost control.Yes, 18psi Link to comment Share on other sites More sharing options...
FGeorge Member 79 Member For: 2y 10m 17d Posted 05/08/21 04:22 AM Author Share Posted 05/08/21 04:22 AM (edited) Bjc, are you saying 18 because of some logic around: Max overboosted psi from turbo mechanically possible is say 24psi and stock wastegate can attenuate 6psi, hence max possible is 18? Wondering then if the earlier comments about going over 18 psi are down to a gauge reading psi incorrectly? What makes you sure that it will max at 18? Edited 05/08/21 04:24 AM by FGeorge (I'm throwing fake numbers around for the sake of a concept) Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 27d Posted 05/08/21 05:31 AM Share Posted 05/08/21 05:31 AM Cause he knows the exact flow characteristics of each component between your air filter and exhaust tip, plus the air pressure/temperature/humidity each time you go full throttle. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,105 Member For: 9y 2m 19d Gender: Male Location: South Australia Posted 05/08/21 07:49 AM Share Posted 05/08/21 07:49 AM I'm just here for the goats 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,281 Member For: 16y 7d Gender: Male Location: Melbourne Posted 05/08/21 07:56 AM Share Posted 05/08/21 07:56 AM where are they? I haven't seen any??? Link to comment Share on other sites More sharing options...
FGeorge Member 79 Member For: 2y 10m 17d Posted 05/08/21 08:30 AM Author Share Posted 05/08/21 08:30 AM Gaz, I'm asking a theoretical question aided by fake numbers (as edited above), of course he doesn't know the exact numbers, that's dumb. He said that there exists a max psi that the small turbo can hit (18psi... Maybe bjc was being sarcastic like you, I dunno. 🌴 Throwing you some shade). I'm being curious, this is a cool topic after all. So if there is a maximum psi that can be achieved, then is that because there is a limit to small turbo psi and a max wastegate relief? then it follows that there is a limit to max actual boost (max turbo psi less max wastegate relief). 1 hour ago, Puffwagon said: I'm just here for the goats You mean you think I'll ghost you and not post my Dyno sheet when it's done? Guilty until proven innocent hey? Haha Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 26d Gender: Male Location: Canberra ACT Posted 05/08/21 08:41 AM Share Posted 05/08/21 08:41 AM Puff is right though. Weld the gate shut and send it. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,105 Member For: 9y 2m 19d Gender: Male Location: South Australia Posted 05/08/21 08:42 AM Share Posted 05/08/21 08:42 AM Yeah nah yeah nah. But yeah...nah. Link to comment Share on other sites More sharing options...
