TomTerritory Member 40 Member For: 2y 10m 6d Posted 05/08/21 07:30 AM Author Share Posted 05/08/21 07:30 AM there doesn’t seem to be any in out play Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 05/08/21 07:38 AM Share Posted 05/08/21 07:38 AM as long as it's not touching the housing, you're generally fine with a few mm of play Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 05/08/21 07:48 AM Share Posted 05/08/21 07:48 AM Hard to tell if your thumb is bending or the shaft is moving. There will be a little bit of shaft play and there will be a little bit of noise. Sometimes you can hear the turbo winding down when you get out of the car after you switch it off. Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 2y 10m 6d Posted 05/08/21 08:00 AM Author Share Posted 05/08/21 08:00 AM Thanks again guys. Really appreciate your replies! Going into lockdown tonight so might have a go at the flapper mod over the next week. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 05/08/21 08:04 AM Share Posted 05/08/21 08:04 AM It's pretty easy to do but make sure you leave a landing area for the closest end of the flap (to the housing) or it could jam open. You can almost make the hole slightly D shaped but not so extreme. Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 2y 10m 6d Posted 05/08/21 08:22 AM Author Share Posted 05/08/21 08:22 AM Yep I understand. Been watching a few youtube videos! Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 2y 10m 6d Posted 07/08/21 05:17 AM Author Share Posted 07/08/21 05:17 AM Pulled the turbo off today, I’m still concerned about the amount of shaft play. I had a look at the new oil feed fitting to the turbo and it has approx 1mm bore hole in the end! It’s full bore hole on the tapered end but on the other end is restricted. I feel like this is a machining error?ill try and upload some photos Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 07/08/21 05:33 AM Share Posted 07/08/21 05:33 AM a lot of ball-bearing turbo's have oil-flow restrictors like that and yours is no exception to needing one Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 07/08/21 05:38 AM Share Posted 07/08/21 05:38 AM A 1mm restrictor is pretty normal for a ball bearing turbo. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 24d Gender: Male Location: Adelaide Posted 07/08/21 08:18 AM Share Posted 07/08/21 08:18 AM (edited) But you’re all missing the fact Garrett GT-GTX-GTW series turbochargers have a built in restrictor and it’s much bigger than 1mm ….. Ohhh Nooo Spaghetti ooooo’s Edited 07/08/21 08:26 AM by JETURBO Link to comment Share on other sites More sharing options...
