PeregrineFalcon New Member 2 Member For: 2y 9m 26d Posted 21/06/21 07:50 AM Share Posted 21/06/21 07:50 AM Hi, I have a G6 which ive done a T conversion on and next step is LSD so I can put the power down. One thing that's got me stumped is im not 100% on the diff it has. Some forums say anything NA has the m80 but I've also read anything with a zf6 has an m86 2.73. Ive checked all the labels the only info they give me is 2.73 ratio which could either be m80 or m86. When I had the cradle out I happened to have a m86 housing and from my dodgy measurements and visual inspection they appeared the same, but does the m80 look significantly different in anyway? Sorry for the ramble I just want to be 100% (im about 80% sure its m86) before dumping $1500, pulling the cradle out and finding I don't have the m86. Cheers! Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 22/06/21 09:28 AM Share Posted 22/06/21 09:28 AM In factory form you 100% have a Single pegger M80 2.72 which has an identical outer housing to the M86 The G6ET also has a single pegger M80 2.72 as all G6ET’s were ZF auto The 2.72 ratio is always coupled up with the ZF gearbox 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 22/06/21 09:33 AM Share Posted 22/06/21 09:33 AM ain't it 2.73, not 2.72? or have they been lying to us the whole time Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 22/06/21 09:34 AM Share Posted 22/06/21 09:34 AM Yeh whatever sticker is on there or depending on what owners manual you read lol Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 7d Posted 24/06/21 12:21 AM Share Posted 24/06/21 12:21 AM In factory form you 100% have a Single pegger M80 2.72 which has an identical outer housing to the M86 The G6ET also has a single pegger M80 2.72 as all G6ET’s were ZF auto The 2.72 ratio is always coupled up with the ZF gearbox So the na and turbo both have the m80?Turbo doesn't have a m86 open centre? Does the m80 and m86 share axles/splines? Link to comment Share on other sites More sharing options...
PeregrineFalcon New Member 2 Member For: 2y 9m 26d Posted 27/06/21 03:14 AM Author Share Posted 27/06/21 03:14 AM I see, I didn't realise they could use the housing. Thanks very much Link to comment Share on other sites More sharing options...
jcg6e08 New Member 4 Member For: 2y 4m 26d Posted 31/10/21 06:47 AM Share Posted 31/10/21 06:47 AM Sorry for jumping in but is the m86 diff an easy swap into the na cradle with the m80? if I have the m86 diff and drive shafts? sorry posted in the wrong section. Link to comment Share on other sites More sharing options...
