jas98 Member 1,029 Member For: 11y 9m 1d Gender: Male Location: Maryborough Qld Posted 21/05/21 09:38 AM Share Posted 21/05/21 09:38 AM Ok have ba xr6t has developed this sound but today it's worse. Started off as a one off noose and went away. Last few days it's been there on and off but now it's there most time but not always. Weired this is....when driveing and coasting you can hear it however if I tough accelerator ever so slightly it disapears but take foot off (and I mean only slightly) goes away. Boosting there's zero noise...boost fine no issues there. I have taken belt off and removed fans and noise still there. Turbo has a little shaft play....has always over the years....fins look good. Factory Oil screen was removed years ago. Does it sound turbo? Maybe a boost leak? Just to me if turbo would and should it not make a huge noise when under boost?? This is the noise (my car) Link to comment Share on other sites More sharing options...
cat007 Member 234 Member For: 5y 7m 20d Posted 21/05/21 11:04 AM Share Posted 21/05/21 11:04 AM Sounds like a vacuum leak? Doesn't sound like turbo and doesn't change with revs. Link to comment Share on other sites More sharing options...
Elite IV New Member 10 Member For: 3y 7m 29d Gender: Male Location: Brisbane, Queensland, Australia Posted 21/05/21 01:17 PM Share Posted 21/05/21 01:17 PM That is one strange noise. Anyone run into this issue before? Never seen it before Link to comment Share on other sites More sharing options...
sixman Donating Members 593 Member For: 19y 9m 2d Gender: Male Location: Hills District, NSW Posted 21/05/21 10:43 PM Share Posted 21/05/21 10:43 PM Almost sounds like the turbo fans or whatever they are called Link to comment Share on other sites More sharing options...
jas98 Member 1,029 Member For: 11y 9m 1d Gender: Male Location: Maryborough Qld Posted 21/05/21 10:57 PM Author Share Posted 21/05/21 10:57 PM Thanks all. Went out and started it from cold and no noise untill about 2 min of idleing. Then noose came in...then when ac clutch tuned on noise dissapears till AC clutch turned off....however as said it done this noise even when belt was off and fans out of car. I put it into reverse and noose dissapears this time. Noose was there in park neutral and also drive. Now I'm.wondering if it's gearbox...maybe bearing in it gone or convertor bearing 😂 Link to comment Share on other sites More sharing options...
jas98 Member 1,029 Member For: 11y 9m 1d Gender: Male Location: Maryborough Qld Posted 22/05/21 01:59 AM Author Share Posted 22/05/21 01:59 AM Fixed ...!!! Was the PCV valve hose.....it was sucking inwards as it was all soft. Would never have thought it would be that but I seen a similar noose on YouTube from a different car. Cheers all 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 22/05/21 06:54 AM Share Posted 22/05/21 06:54 AM excellent result Link to comment Share on other sites More sharing options...
