Sean4.0 New Member 21 Member For: 2y 11m 28d Posted 03/05/21 06:09 AM Share Posted 03/05/21 06:09 AM Ok brains trust, After enjoying my newly tuned ute I have encountered a problem that has me off the road. Last week for the first time ever, I started the car and it died soon after settling into an idle. It refused to restart... cranking over but not firing. We couldn't hear the (New 460L) fuel pump priming so we beat on the bottom of the fuel tank without any change. After trying for 10 minutes it fired back into life and we let it idle for 10 minutes and drove it home and had no further issues for a week. Until today, the car died in heavy traffic and refused to start. Same issue, fuel pump not priming, cranking but not starting. Had to get it towed home.... and after spending the afternoon checking all fuses, relays and wiring looms I am stuck. Being a ute, access to the fuel pump is difficult by myself so any ideas before I pull off the tub and check power to the pump? One thing that I did notice on reflection is that the idle has been a little rough... just a slight stumble now and then, not smooth like I remember. This is the pump I bought: https://www.ebay.com.au/itm/263186008738 Was I a sucker who purchased a fake pump? Thanks in advance, Sean Link to comment Share on other sites More sharing options...
Sean4.0 New Member 21 Member For: 2y 11m 28d Posted 03/05/21 06:48 AM Author Share Posted 03/05/21 06:48 AM (edited) Update: Just spoke to the guy who built the pump/drop in assembly and he assures me that it's a genuine Walbro pump and "these never fail" He told me to check fuses and relays which I already have. He said to check the wiring harness plug at the fuel pump, so I'll endeavor to do that. I asked if the 460L needed a dedicated power wire, but he assured me that it doesn't (which was my understanding too). He seams genuine and even gave me his mobile number so he can walk me through what to check when I have the plug off. Just a bit disappointing after getting the car setup and finally registered in NSW to have these issues.... oh well... could be worse. Edited 03/05/21 06:51 AM by Sean4.0 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,240 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 03/05/21 07:53 AM Share Posted 03/05/21 07:53 AM usually the higher current draw of a bigger pump like that requires a higher gauge of wiring to suit it. Link to comment Share on other sites More sharing options...
adams355 Member 529 Member For: 6y 10m 28d Gender: Male Location: Brisbane Posted 03/05/21 08:06 AM Share Posted 03/05/21 08:06 AM (edited) The 460 Walbro will only pull 18-19 amps maximum so in theory you can get away with the stock wiring and a lot of people have including me but there isn't much room for error or spikes or what not. That ebay guy is a trusted seller I have bought a few things off him through the years. Symptoms sound like pump though as you said. Check the connection from the pump to under the module top as well. Edited 03/05/21 08:15 AM by adams355 Link to comment Share on other sites More sharing options...
Sean4.0 New Member 21 Member For: 2y 11m 28d Posted 07/05/21 11:59 PM Author Share Posted 07/05/21 11:59 PM Ok, so I have the ute tub off and am trying to diagnose the issue. SOMETHING ELSE STRANGE is happening.... The ute now wants me to depress the clutch before it will crank the engine? It's never done this before. Is this a symptom of low battery voltage? I ran the battery low trying to start it earlier in the week and have had it on charge over night now that I'm home from work. Link to comment Share on other sites More sharing options...
Sean4.0 New Member 21 Member For: 2y 11m 28d Posted 08/05/21 12:45 AM Author Share Posted 08/05/21 12:45 AM AND..... the ute started and idles fine today!!! I hate intermittent problems. Link to comment Share on other sites More sharing options...
Sean4.0 New Member 21 Member For: 2y 11m 28d Posted 25/05/21 05:12 AM Author Share Posted 25/05/21 05:12 AM New fuel pump installed and everything is back to normal. Link to comment Share on other sites More sharing options...
