  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 30d
yes, you shouldn't run a stock tune with mods that change fuel flow or exhaust flow characteristics... some air-flow characteristics can be changed.
  • Member For: 4y 3m 15d
Oh okay, I just asked my mechanic about changing my valve  springs and he said it will cost 2000-2500 for the install. But I’ve read every else people say 600-700 for labour and about 400 for the springs. If anyone could help with advice would be helpful
And thanks for the advice from before
  • Site Developer
that's a ridiculous price... buy the valve springs and retainers and get a cheaper mechanic to quote you for the labour.
  • Site Developer
tell him he's wrong, as you don't need to remove the head to change the valve springs... yeah, that's a fairly average price, 800-1400 depending on labour rates and the purchase price of the valve springs.
Okay thank you for the help, I guess I’ll get some more quotes and no go through with my mechanic
And how do you remove the valve springs and install new ones without removing the head?
  • Site Developer
you use a tool that holds the valves in place via a pressure connection that goes into the spark plug hole that pushes against the valves falling into the cylinders... this same tool is usually used to also compress the springs to get the retainers out and put the new springs and retainers without having to stuff about too much with clamps or something else equally dodgy haha
