01txr Member 861 Member For: 17y 2m 14d Gender: Male Location: QLD Posted 21/04/21 03:45 AM Share Posted 21/04/21 03:45 AM Ive just recieved my vclamp 6boost maniflod to suit my new g35-1050. In comparing it to my TO4z split T4 manifold (Taz?, purchased from Hi Torque some years ago), the 6boost has 42mm od tube and the Taz has 48mm od tube. The head flange on the 6boost tapers down smaller to suit tube ID, wear as the taz manifold is consistant size. Also without looking, Im sure I opened the exhaust ports up a little and this may make the reduction worst once I match port the flange. Im Thinking the big tube would be better for hp. Whats everyones thoughts? Are the small tubes better for air speed hence quicker spool response? Will the small tube restrict top end hp? Is anyone running a g35-1050 6boost combo? How have you found it? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 21/04/21 08:25 AM Share Posted 21/04/21 08:25 AM I've made over 900whp with a 6boost. I suppose some back pressure testing is needed to see where it becomes a restriction. 1 Link to comment Share on other sites More sharing options...
