Tom Tucker Donating Members 615 Member For: 4y 9m 26d Posted 11/04/21 03:03 AM Share Posted 11/04/21 03:03 AM I think big auto converters can get some of those big turbos moving much earlier than a manual, and stuff like antilag is becoming more common. And yep, flow above 500-550kw is compromised. I think even forged pistons break ring lands or melt Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 11/04/21 03:50 AM Share Posted 11/04/21 03:50 AM 57 minutes ago, TRYME said: why people like these cars with the large frame turbos e.g. gtx 42 and larger I've got awd so it means I actually get moving instead of smoking it up. I've had 600awkw dead hook in second gear on a sticky summer hwy. Going from a 66mm garrett on a stock manifold to a 76mm aeroflow on a 6boost manifold only sacrificed about 500rpm, so I'm happy with that, and with a 3500rpm converter it will probably spool like a stock turbo car again. Also the car drives quite decently off boost so it's not slow for everyday driving. But yerp I can see both sides of the coin, and I think awd is the saving grace for me. I reckon it would suck in a rwd car. 13 hours ago, TRYME said: for a STREET car the GTX 3582 & G35 sized turbos (and other manufacturers equivalents) are about perfect for them lag is minimal and they make enough power to keep 99% of people happy Haha I'm definitely the 1% Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 26d Posted 11/04/21 04:56 AM Share Posted 11/04/21 04:56 AM I thought the Territory transfer case was weak? You don't seem to have issues? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 11/04/21 05:08 AM Share Posted 11/04/21 05:08 AM Nah I haven't really had any problems with it. It's made a funny noise once or twice when the power transfer through the wheels has changed rapidly but apart from that it's been ok. Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 17y 3m 11d Gender: Male Location: QLD Posted 11/04/21 10:36 PM Author Share Posted 11/04/21 10:36 PM Latest is I am possible off loading the 7075, and going the g35-1000, not sure to go the 1.01 or 1.21 rear. The to4z is off the top of my head a 1.06. Built boost from 1100rpm in top gear, 12psi by 1500rpm. Don't mind losing a bit of low down response. Eg. Build boost from 1500rpm min to 2000rpm max with it making 20psi by 3000rpm. Debating to buy 1.21 giving it a go, if response is too late then buy a 1.01. Link to comment Share on other sites More sharing options...
TRYME Member 313 Member For: 3y 2m Posted 12/04/21 07:33 AM Share Posted 12/04/21 07:33 AM 01txr You gonna go genuine garret im assuming? And puff mate I think awd is your saving grace hahaha that territory sounds like a real beast 600kw Hooking up would be insane Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 17y 3m 11d Gender: Male Location: QLD Posted 12/04/21 08:29 AM Author Share Posted 12/04/21 08:29 AM Yeah genuine, after reading info on its build specs and the dollars spent on my engine, I've decided to go the g35-1050. Mainly as I've found one 1.01 and .83 at a good price. Just need to try work out which one, 1.01 or .83. Tending towards the 1.01. Be really good if I could find out a comparison between to4z 1.06 vs G35-1050. 83 and 1.01. Then there's the 1.21 will it be too laggy. Think I'll try the 1.01 and see how it performs then decide to go up or down. Also my to4z is t4 split. Is the vband flange better or not as good? Theres no T4 option for the G35-1050. And awd would be great in the falcon on street, mmmm. But more weight and Id be worried about its strength on circuit use. Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 26d Posted 12/04/21 08:49 AM Share Posted 12/04/21 08:49 AM Have you looked at the Precision turbos? 6466? Or Borg Warner EFR 9180? Both of these have T4 turbine housings. Link to comment Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 13y 3m 16d Gender: Male Posted 12/04/21 10:00 AM Share Posted 12/04/21 10:00 AM Be nice to know if garret plan on making t4 versions. Ive seen u can get g35 supercores but I assume that’s just for the vband rear housing. I think I read something that the rear housing has a different more efficient shape, maybe it all goes together better as vband?Someone said to me a 6boost isnt that much but would be good if the g35s which are the successors to the gtx gen 2s were truly an oem replacement as their predecessors were. Link to comment Share on other sites More sharing options...
TRYME Member 313 Member For: 3y 2m Posted 12/04/21 11:34 AM Share Posted 12/04/21 11:34 AM (edited) 6 boosts aren't overly expensive but if you add up the price of a g35, 6 boost, dump pipe to suit, external gate set up etc it's alllooot of money over a gtx35 on a internally gated factory rear housing on a standard manifold is it better I ❤️ Bananas oath,, but it's a lot of money when the gen 2 can make 550 on the standard manifold if a g35 would fit on standard stuff and was bolt on replacement that would be heaven haha you guys reckon they'll come down in price once they been around for a while or nah no chance? Wonder why garret won't offer em in t4 ay,, I know a car with a BW on it apparently great turbos it's makin 630rwkw Edited 12/04/21 11:37 AM by TRYME Link to comment Share on other sites More sharing options...
