Hellz K9 New Member 5 Member For: 3y 1m 19d Posted 05/03/21 06:29 AM Share Posted 05/03/21 06:29 AM I've striped the interior of this car so no ICC, BEM or cluster. I've got the the security stripped of the ECU so the car runs fine. I want oil pressure, engine temp and tach gauges but I don't know enough about it all. I have heard the easiest thing to do for the tach is join into the injector pulse, ideas? Can I use the existing head temp sensor with a different gauge? Is the best thing to do for the oil is to tee off the oil pressure gauge and add a new sender? Cheers Link to comment Share on other sites More sharing options...
Hellz K9 New Member 5 Member For: 3y 1m 19d Posted 21/03/21 11:19 PM Author Share Posted 21/03/21 11:19 PM Turns out that OBD2 reader and gauge sets are very cheap, so I'll try that. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 2d Gender: Male Location: Canberra ACT Posted 22/03/21 12:31 AM Share Posted 22/03/21 12:31 AM That should sort you for temps etc. Some can be a bit slow in terms of refresh rate so might have to see how it goes for RPM.The car won't have oil pressure through OBD as it only has an oil pressure switch (rather than sensor). You can I stall a T piece into the switch location to add a sensor and gauge. Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,370 Member For: 5y 26d Gender: Male Location: Perth, WA Posted 22/03/21 02:15 AM Share Posted 22/03/21 02:15 AM You can get one of them power tune digital dash units. Will give you most of what you’re looking for except the oil pressure. 😊 Link to comment Share on other sites More sharing options...
Hellz K9 New Member 5 Member For: 3y 1m 19d Posted 22/03/21 11:21 PM Author Share Posted 22/03/21 11:21 PM Thanks gents I will look into this. RPM isn't to much of an issue car is limited anyway but I will put a oil pressure gauge and sender in. Link to comment Share on other sites More sharing options...
