Ammf6 New Member 22 Member For: 3y 1m 22d Posted 28/02/21 08:01 AM Share Posted 28/02/21 08:01 AM I’ve just installed a new turbo on my 2006 bf xr6 turbo , Same stock turbo no mods , my old turbo bearings sh*t itself . Installed the new app turbo , the car runs fine now , however after about 10 minutes of driving the car will start to idle real rough almost like it’s going to run out of fuel.. if I let it sit and rest for a bit it’s fine but then will do the same process . Would this be a coil / spark plug issue ? I’ve changed the oil , oil filter fuel filter . Next will be the coils and plugs . Anyone had this issue Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 28/02/21 08:43 AM Share Posted 28/02/21 08:43 AM if it only happens when it's 10min into driving, it sounds more like something related to the thermostat... e.g. something in the cooling system isn't liking being used in the extra cooling flow or the extra parasitic drain of the water pump on the system may be causing something else attached to the pulley systems to be running slightly out of spec... but coils and plugs is always a good way to go, trouble-shooting wise, with regard to any falcon that's running rough. Link to comment Share on other sites More sharing options...
Ammf6 New Member 22 Member For: 3y 1m 22d Posted 28/02/21 09:15 AM Author Share Posted 28/02/21 09:15 AM Is there a way of checking the cooling system ?? The turbo oil return line to sump was blocked , small pin hole which Was what caused the turbo to fail I’m guessing . The previous owner may have not looked after her / regular oil changes ect I’m guessing . Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 28/02/21 09:24 AM Share Posted 28/02/21 09:24 AM I swear you are on crack sometimes k31th OP, think about what's changed cos you probably farked it up yourself if it was fine before. Check that you haven't disturbed a sensor near where you were working. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 28/02/21 09:36 AM Share Posted 28/02/21 09:36 AM well, I'm just hypothesizing... so, not sure how that means I'm on crack haha Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 28/02/21 09:48 AM Share Posted 28/02/21 09:48 AM 56 minutes ago, k31th said: something in the cooling system isn't liking being used in the extra cooling flow or the extra parasitic drain of the water pump on the system may be causing something else attached to the pulley systems to be running slightly out of spec... That kinda reminds me of this. Haha I'm only stirring mate but still, I have to wonder Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 28/02/21 09:49 AM Share Posted 28/02/21 09:49 AM yeah, I get you're stirring... no way is it anything close to what she did, though. Link to comment Share on other sites More sharing options...
Ammf6 New Member 22 Member For: 3y 1m 22d Posted 28/02/21 09:00 PM Author Share Posted 28/02/21 09:00 PM The car Was doing this just before the turbo went . Link to comment Share on other sites More sharing options...
