Rob70 Silver Donating Members 82 Member For: 3y 11m 18d Gender: Male Location: Wellington, NZ Posted 15/04/21 01:48 AM Share Posted 15/04/21 01:48 AM I'm from Kapiti, my mate purchased a BA tuned at TMS, it's around 320rwkw and goes pretty good. I've not had any work done at Prestige but they seem like a pretty switched on outfit, @canedkyddseems to rate them. I had mine tuned in Fielding by Keith Stewart, got 407rwkw and then settled on 381rwkw tune to help the driveline live a little longer. We haven't got the same luxury over here as Straya has with several really good Barra tuners. Link to comment Share on other sites More sharing options...
X-xyk Member 37 Member For: 3y 9m 21d Posted 15/04/21 02:11 AM Share Posted 15/04/21 02:11 AM Ah alright might give tms a go, since they're only a 20 minute drive, cheers for that Link to comment Share on other sites More sharing options...
canedkydd Member 56 Member For: 3y 10m 11d Gender: Male Location: Wellington New Zealand Posted 15/04/21 02:39 AM Author Share Posted 15/04/21 02:39 AM be interesting to see what you think of them. I am pretty happy with Prestige. stock other than 1000cc injectors I got 300rwkw. had an issue after tune on the dragstrip of a miss under load called Chris and he said get in in asap and he will sort it. tested again on dyno first and all was good and in fact on the street giving it a beating it performed awesome. Chris then took it to a (closed road) for testing and then was able to notice the miss. you cant replicate that on the dyno. closed the gap on the plugs slightly problem sorted. These guys take pride in every tune they do and will go the extra mile to make sure you are happy. Link to comment Share on other sites More sharing options...
cat007 Member 234 Member For: 5y 6m 24d Posted 15/04/21 06:48 PM Share Posted 15/04/21 06:48 PM What gap are you running? I'm running OEM 0.7mm I think from an LPG motor. Link to comment Share on other sites More sharing options...
canedkydd Member 56 Member For: 3y 10m 11d Gender: Male Location: Wellington New Zealand Posted 15/04/21 07:31 PM Author Share Posted 15/04/21 07:31 PM Now running 0.7mm from I think 0.9mm Link to comment Share on other sites More sharing options...
cat007 Member 234 Member For: 5y 6m 24d Posted 15/04/21 07:35 PM Share Posted 15/04/21 07:35 PM Perfect. The LPG plugs are the same as the turbo ones, they just come pre-gapped at 0.7mm. Link to comment Share on other sites More sharing options...
1XR2NV New Member 7 Member For: 2y 11m 5d Posted 23/04/21 07:03 AM Share Posted 23/04/21 07:03 AM When are you taking it down the quarter mile? Link to comment Share on other sites More sharing options...
canedkydd Member 56 Member For: 3y 10m 11d Gender: Male Location: Wellington New Zealand Posted 23/04/21 09:28 AM Author Share Posted 23/04/21 09:28 AM unfortunately only got one run after tune but due to miss that it was getting I didnt take it back out ran 13.2 @ 109mph missing all the way down the qtr. have tested since taking back to tuner and is really going well but track dont open for months. will post times when it reopens 1 Link to comment Share on other sites More sharing options...
Snowbear77 Member 102 Member For: 3y 7m 6d Gender: Male Location: Perth Posted 24/04/21 12:19 PM Share Posted 24/04/21 12:19 PM I've been quoted $1250 from MONSTA TORQUE in perth............. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 24/04/21 12:22 PM Share Posted 24/04/21 12:22 PM is that including springs? if so, that's alright, if not, the cost is too high and you should go with a mechanic that has a lower hourly rate to do the labour intensive work that is valve springs. Link to comment Share on other sites More sharing options...
