fox1972 Member 46 Member For: 5y 6m 11d Posted 16/12/20 08:26 AM Share Posted 16/12/20 08:26 AM Hi everyone, I have a Ba Xr6t MkII manual with the t56 6 speed. The other day my concentric slave failed in my box, and I have fluid dripping out of the bell housing. I ordered a new concentric slave from mal wood with the remote bleeder to replace it. In the past, I have pulled out heaps of T5's but never a T56. Can someone that has done one, just walk me through on the removal procedure. Regards Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 16/12/20 08:46 AM Share Posted 16/12/20 08:46 AM 17 minutes ago, fox1972 said: I have pulled out heaps of T5's but never a T56 Same as any old tractor gear box. You've done one you've done them all. That being said...If you need walking through a gearbox removal you shouldn't be attempting it. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 16/12/20 08:53 AM Share Posted 16/12/20 08:53 AM (edited) Pretty much identical to a T5 really Gearbox leaver boot up on central console gearbox leaver unbolted x2 bolts 13mm tailshaft out, spare yoke in or zip lock bag around output shaft to stop oil leaking out on elevation T56 body away from Bell housing rear trans mount away from chassis remove CSC bolts and let it hang drop T56 remove bell housing away from rear of engine if you need to access the clutch as it’s probably contaminated with Hydraulic fluid and buggered now remove clutch pressure plate remove clutch disks remove flywheel remove spigot bearing Job out done........ Reverse it to put in Edited 16/12/20 08:54 AM by JETURBO 1 Link to comment Share on other sites More sharing options...
fox1972 Member 46 Member For: 5y 6m 11d Posted 16/12/20 08:54 AM Author Share Posted 16/12/20 08:54 AM Thx jet... That's all I need to know. I wasn't sure if I could just pull the box away on it's own, without removing bell housing, mainly due to the hydraulic line to the concentric. I have the ba workshop manual, but it doesnt have the t56 specs in the book I've got. 4 hours ago, Puffwagon said: Same as any old tractor gear box. You've done one you've done them all. True true..... I'm totally over with getting under the car, getting to old for it, but I cannot get it in the shop, because I won't have the part till next week, and all the shops here close for xmas next wednesday, and will not resume till the 11th of next month. I'm not waiting that long. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 16/12/20 09:26 AM Share Posted 16/12/20 09:26 AM Fair...enough Link to comment Share on other sites More sharing options...
