Snoochie Boochies New Member 2 Member For: 3y 5m 14d Posted 10/11/20 08:51 AM Share Posted 10/11/20 08:51 AM Hi All, Hoping I could get some valuable feedback from the members on this forum, I am currently in the process of swapping over the standard turbo on my FG MK2 xr6 turbo to a GTX3582r and I have a question regarding vacuum lines. On the standard GT3576R there 2 vacuum lines, one going to the internal wastegate actuator and the other goes to the front compressor housing. With the GTX3582r there isn't a fitting on the compressor housing like there is on the standard FG turbo. The question that I have is what do I do with the extra vacuum line?? Any feedback would be greatly appreciated. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 10/11/20 09:15 AM Share Posted 10/11/20 09:15 AM You need to connect it to a boost source. You'll need to put a fitting into the comp housing or into the boost pipe coming from the turbo. Link to comment Share on other sites More sharing options...
Snoochie Boochies New Member 2 Member For: 3y 5m 14d Posted 10/11/20 09:39 AM Author Share Posted 10/11/20 09:39 AM (edited) Thanks for your reply Puffwagon, I have attached an image of the GTX3582r, there is a speed sensor port on the compressor housing is this where the vacuum line needs to go to? Edited 10/11/20 09:39 AM by Snoochie Boochies Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 10/11/20 10:03 AM Share Posted 10/11/20 10:03 AM I dunno if you could get a fitting to fit the speed sensor hole as it is a fine thread. Unscrew it and have a look. I just drilled and tapped a hole into the comp housing, and with another setup I put a fitting into the intercooler pipe after the turbo. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 10/11/20 12:18 PM Share Posted 10/11/20 12:18 PM 3 hours ago, Snoochie Boochies said: On the standard GT3576R there 2 vacuum lines, one going to the internal wastegate actuator and the other goes to the front compressor housing. With the GTX3582r there isn't a fitting on the compressor housing like there is on the standard FG turbo. There's a nipple on the front of the stock turbo that goes to the boost control solenoid and then a separate line comes out of the solenoid and goes to wastegate nipple. If the GTX3582R you have doesn't have a nipple to connect to you do what Puffwagon said and drill+tap a line and then run it the same as the stock turbo was. 2 Link to comment Share on other sites More sharing options...
