bacinman33355 New Member 2 Member For: 3y 5m 22d Posted 03/11/20 05:25 AM Share Posted 03/11/20 05:25 AM (edited) Not sure if this is the right section but I have some 245 35z r20 inch wheels that wont spin on the front of my 2006 BF Falcon, the ones that were on it are the same size and the contact point on the tyre has already been rubbed off so they spin. Both old tyres have been worn equally but is it possible to shift the suspension knuckle where it hits back or up a few mm? Edited 03/11/20 05:30 AM by bacinman33355 incorrect number Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 03/11/20 07:43 AM Share Posted 03/11/20 07:43 AM you don't shift the knuckle, you use a spacer to move the wheel outwards a few millimetres... or you shave the knuckle with an angle-grinder if you want to get really agricultural. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 03/11/20 09:32 AM Share Posted 03/11/20 09:32 AM (edited) If it's hardly farken touching it then grind it a little bit. Edited 03/11/20 09:33 AM by Puffwagon Who doesn't love an edit? 1 Link to comment Share on other sites More sharing options...
bacinman33355 New Member 2 Member For: 3y 5m 22d Posted 03/11/20 09:37 AM Author Share Posted 03/11/20 09:37 AM its made pretty decent contact but yeah ill give it a shot, it stops the whole wheel its not like a graze Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 03/11/20 09:53 AM Share Posted 03/11/20 09:53 AM Have a look at the space between the rotor and the rim at the top, where the rim attaches to the rotor, with the wheel nuts barely nipped up. If it's tiny then you don't have far to go, if there is more than a mm or two then you're probably SOL. 2 hours ago, k31th said: use a spacer to move the wheel outwards a few millimetres This could be and probably is the right way to go. Grinding is fine but use common sense. 1 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 4d Posted 03/11/20 10:03 AM Share Posted 03/11/20 10:03 AM You really need a 245/30 or 225/35. But I have made it work using a 245/35 using a 3mm wheel spacer and grinding the edge slightly. Admittedly I never got it to clear with a brand new tyre. 1 Link to comment Share on other sites More sharing options...
