Gman98 New Member 5 Member For: 3y 6m 3d Posted 21/10/20 03:21 AM Share Posted 21/10/20 03:21 AM (edited) I just wanted to learn more knowledge on my car and what I should do to reach my current goal of around 330-370rwkws, I wouldn't push any more further as I know I would be likely to do a zf rebuild so far my car has only pushed for 235kw at the wheels when iI tuned it as the previous owner returned it down as close to stock form again, they've put a Chinese turbo on as opposed to the original Garret which didn't climb enough as id expected it do FG Mk2 Full 3'5 xforce system High flow cat 1000cc injectors KN Air Filter (still stock piping) Valve springs and headstuds (thanks to previous owner) Autotechnika intercooler I am expecting to upgrade the cooler and do a full piping kit also to a Plazmaman 1000hp cooler & since I don't have the stock turbo figured I'd be better off going straight for a GTX3582R Gen2 Any suggestions or recommendations on other supporting mods? Edited 21/10/20 03:22 AM by Gman98 Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 17y 8m 8d Gender: Male Posted 21/10/20 12:50 PM Share Posted 21/10/20 12:50 PM If you only want 370 then I would choose a GTX3576R over the 82R. Will almost spool as good as the stock turbo and easily get you the power you are chasing Link to comment Share on other sites More sharing options...
