cmf60 New Member 2 Member For: 3y 7m 28d Posted 29/09/20 11:51 PM Share Posted 29/09/20 11:51 PM Hi guys, I recently brought an FG XR6T auto ute with 90k's on it. The thing seems to go quite well but the engine goes quite harsh when revved right out and sounds like it might be floating valves. I have read that they suffer from poor valve springs .... but before spending the $'s I thought I'd ask - is that harshness typical of them or does it need springs ?? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 30/09/20 12:24 AM Share Posted 30/09/20 12:24 AM Valve springs going soft is not typical of a stock car, but one that was previously modified yeah definitely a common symptom... also you can confirm it's valve springs if you're giving it the beans and it "breaks down" at higher revs then when you slow down to an idle the idle will be rough, too, as the springs return to their "before giving it the beans" state. If it only goes bad when it's at higher revs with boost, then ignition coils or spark plug gap are more likely to be the cause. Link to comment Share on other sites More sharing options...
cmf60 New Member 2 Member For: 3y 7m 28d Posted 01/10/20 09:33 AM Author Share Posted 01/10/20 09:33 AM No I haven't noticed any signs of lifter pump-up (I assume that's what your referring to) ... Will try some fresh plugs in it first and see if that cleans it up. Thank you for your input. Link to comment Share on other sites More sharing options...
