bjc Donating Members 2,807 Member For: 20y 6m 24d Gender: Male Location: Townsville Posted 29/11/21 06:47 AM Share Posted 29/11/21 06:47 AM Ok, so I'm mining as usual so I don't have to start another thread... I think I want to buy a FPR for the stock fuel rail (territory turbo) so while there are still discounts until midnight can I get some feedback on which is the preferred drop in FPR unit to get? I've got the options of the - GFB from IMS at $264 and get a $30 turbosmart gauge (unless the GFB is accurate, it looks cheap?) or $100 150psi fuel pressure sensor. - Turbosmart $329 drop in unit (FPR800 & gauge) from Goleby's or finally - Aftermarketindustries $399 (Turbosmart FPR1200) drop in kit from Goleby's with extra gauge available $31 or 150psi sensor $99??? The only other option I could think of would be getting an inline gauge or sensor so I know what the stock fuel pressure is considering I'll be doing my own tuning (learning mostly and I'm new to it) over a number of years I need data to look at as I'm sh*t for brains without it these days... All replies welcome from people with experience @JETURBO @Puffwagon and friends! Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 29/11/21 08:07 AM Share Posted 29/11/21 08:07 AM The reg required is due to the return fuel flow. Big pump means big return/reg for the most part. It's only something you upgrade if necessary, so needless to say... Only upgrade if necessary! You'll know when a pump is running out cos you'll have solid afr's to redline at lower boost and eventually adding boost will make it lean out, even though the commanded fuel hasn't changed. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,807 Member For: 20y 6m 24d Gender: Male Location: Townsville Posted 29/11/21 08:27 AM Share Posted 29/11/21 08:27 AM I've got a walbro 460 but to install it will be fk knows how many months away. I think the way I'm wired now (my brain, not the car) I struggle to grasp things easily unless I'm doing them all the time which with the laptop and datalogging I'm not plus I've always been better doing manual labour than looking at data so if I can see the actual fuel pressure or be able to change the pressure it's another data point I can put with injector duty cycle, lambda etc... Does that sound dumb? I can't write it down any easier as I'm a layman! I guess I figured if I'm going to install a FP sensor inline and drill out the stock reg after the 460 pump install then a drop-in FPR might have been worth it as it's a mechanical thing I can actually change... Seems I'm trying to talk myself into it lol Thanks for the feedback as usual. I'm sure I'll ponder until the last minute and impulse buy a turbo at the final minute instead Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 29/11/21 08:50 AM Share Posted 29/11/21 08:50 AM A 460 on stock wiring and reg can be tuned around, the way the pcm works it will take care of it anyway, even if it's not tuned...but it ain't recommended lol. Don't waste time drilling a stock reg, a direct fit only cost a few hundred clams anyway. The sensor will go in place of the gauge in the reg. They are handy but experience can also tell you when fuel pressure is dropping. 1 Link to comment Share on other sites More sharing options...
bjc Donating Members 2,807 Member For: 20y 6m 24d Gender: Male Location: Townsville Posted 29/11/21 09:02 AM Share Posted 29/11/21 09:02 AM Cheers, yeh I don't have the wideband wired atm but the LTFT is pulling 21% idling so I'm chasing an issue. I was positive it was always around -3-5% just from my gauges but it's a next year job now as we head to the Gold Coast on Friday. I'll upgrade the wiring for the pump and run bulkheads through the surge pot lid. Pretty sure I have copper or brass bulkheads somewhere from car audio days. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,807 Member For: 20y 6m 24d Gender: Male Location: Townsville Posted 29/11/21 09:24 AM Share Posted 29/11/21 09:24 AM Does anyone else want to throw there 2 cents in for me spending dollarydoos? @k31th? Lol Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,367 Member For: 4y 11m 28d Gender: Male Location: Perth, WA Posted 29/11/21 09:55 AM Author Share Posted 29/11/21 09:55 AM If you're looking to push more power in the future, and you plan to add more pump and stuff, you're gonna need an fpr anyway. So, if its on sale now I'd get it now. that's my 2 cents anyway 😂 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 29/11/21 10:09 AM Share Posted 29/11/21 10:09 AM @bjc, it ain't my money you spend what your budget allows haha 1 Link to comment Share on other sites More sharing options...
bjc Donating Members 2,807 Member For: 20y 6m 24d Gender: Male Location: Townsville Posted 29/11/21 11:04 AM Share Posted 29/11/21 11:04 AM 1 hour ago, biddie_fiddler said: If you're looking to push more power in the future, and you plan to add more pump and stuff, you're gonna need an fpr anyway. So, if its on sale now I'd get it now. that's my 2 cents anyway 😂 What FPR did you end up going with? Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,367 Member For: 4y 11m 28d Gender: Male Location: Perth, WA Posted 29/11/21 11:27 AM Author Share Posted 29/11/21 11:27 AM I didn't need one as I went with a walbro 255 My future plan is to install the kpm 1000hp drop in fuel module, and it comes with a fpr, hence why I've not bothered purchasing one previously 1 Link to comment Share on other sites More sharing options...
