NA_TURBO Member 532 Member For: 8y 6m 14d Gender: Male Location: Mildura Posted 11/08/20 11:36 PM Share Posted 11/08/20 11:36 PM Have you checked to make sure the engine mounts are done up tight? What about the exhaust mounts? Have you checked/replaced those? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 12/08/20 12:39 AM Share Posted 12/08/20 12:39 AM What about the 3rd front bush and transfer case bush. How are the Tailshaft bearing. ? 1 Link to comment Share on other sites More sharing options...
AndyF6X New Member 17 Member For: 3y 8m 22d Posted 12/08/20 11:52 AM Author Share Posted 12/08/20 11:52 AM Engine mounts brand new and done up tight, tail shaft bearing not very old and looks ok. not sure if exhaust mounts would cause a vibration.The vibration feels like its now up front. Thanks for your comments, everything helps. Regards AndyF6X Link to comment Share on other sites More sharing options...
burkey05 Member 76 Member For: 10y 5d Gender: Male Location: Melbourne Posted 12/08/20 12:52 PM Share Posted 12/08/20 12:52 PM (edited) Have you changed ALL THREE diff bushes up front. People often only do the two bushes on the passenger side and not the "3rd diff bush" on the drivers side. Many have said that this has been the cause of the vibrations you are describing under load. pic of "3rd diff bush" Edited 12/08/20 12:54 PM by burkey05 uploading pic Link to comment Share on other sites More sharing options...
AndyF6X New Member 17 Member For: 3y 8m 22d Posted 12/08/20 11:06 PM Author Share Posted 12/08/20 11:06 PM Hi Burkey05 Not sure what I'am looking at in your picture. Is your 3rd bush your talking about the same as the rear engine mount/gearbox mount part number A6016 as I cant see any other bushes on the drivers side. Thanks AndyF6X Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 12/08/20 11:44 PM Share Posted 12/08/20 11:44 PM https://www.ebay.com.au/itm/SpeedyParts-Suits-Ford-Territory-SX-SY-SZ-AWD-Front-Right-Hand-Side-Diff-Bush/233502939764?hash=item365ddc1a74:g:DSEAAOSwNaBeUNmt transfer case https://www.ebay.com.au/itm/Rear-Engine-Mount-For-FORD-Territory-SY-AWD-Barra-190-245T-182-Auto/152956397034?fits=Model%3ATerritory&hash=item239ce965ea:g:TdAAAOSwR4tdXU5~ 1 Link to comment Share on other sites More sharing options...
AndyF6X New Member 17 Member For: 3y 8m 22d Posted 12/08/20 11:54 PM Author Share Posted 12/08/20 11:54 PM Hi Arronm Does my AWD turbo territory have both right hand diff bush and mount. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 13/08/20 01:04 AM Share Posted 13/08/20 01:04 AM Yes 2 on passenger side and 1 on drivers side. How many Ks the car done. ?? Link to comment Share on other sites More sharing options...
AndyF6X New Member 17 Member For: 3y 8m 22d Posted 13/08/20 04:14 AM Author Share Posted 13/08/20 04:14 AM Hi Arronm Ok found it. The 2 on the passenger side have just been done but I didn't know about the one on the drivers side but had a good look and it looks in good shape, it also looks more like a locating bush mounted vertically rather than horizontally. Can this bush be removed and replaced from the bottom? The second part you mentioned ,rear gearbox mount I have ordered and will do the two together. So far I have replaced 3 X rear diff bushes. 2 X front left diff bushes. 2 X engine mounts. If the front right diff bush and rear gearbox mount doesn't fix it I only have drive shafts left. Thanks AndyF6X Link to comment Share on other sites More sharing options...
AndyF6X New Member 17 Member For: 3y 8m 22d Posted 13/08/20 04:24 AM Author Share Posted 13/08/20 04:24 AM 230,000Ks Link to comment Share on other sites More sharing options...
