Alman
BA xr6t ute chasing 300-350rwkw
Hi all,
Long time lurker here and hopefully I've done enough research in regard to what I'd like to do on my r.
Currently have a BA XR6T ute which will be a daily so not after a monster but more so reliabilty and some extra power.
Basically I am planning to perform the following myself
3.73 rear end swap with rebuilt LSD (not after truetrac)
Walbro 460 e85
1000cc injectors with new standard 4bar regulator
Retain BTR, currently running fine
Retain standard air intake with crossover
HDI cooler kit (rated to 700hp), not sure how these go with heatsoak?
Retain factory turbo, no shaft play or noise etc, not sure if flapper mod needed?
Turbosmart 12PSI actuator with new factory boost solenoid
Crow valve springs
Obviously make sure rest of factory items are top notch like plugs and coils etc
Plans are to run E85 at all times fuel costs aren't really an issue
Looking to perform most installation of mods myself, have worked on car for a while and then send it over to a reputable tuner and go from there
If anyone has a similar set up could you please let me know how you went overall and also if I have missed anything vital that would be much appreciated.
Share this post
Link to post
Car already has a larger dump with 100 cell cat, unsure of entire system as it's definitely not stock however overall quiet. Im guessing single 2.5 to 3 if anything. Id rather keep the system on as is since it isn't loud at all however dump and cats are upgraded
Share this post
Link to post
    No registered users viewing this page.
